Question about Magic Chef CAV4004AWW 12 CYCL SUPR. CAP. PLUS 2 SP BRAND IN STOCK
Tub belt broken and needs to be replaced, I have belt but how?
  • 313 Answers
Dryers are very simular to each other. Here is a link that will give you some free video's youj can watch that will help you step by step..
I hope this helps...
Randy
http://video.google.com/videosearch?q=how%20to%20replace%20belt%20on%20magic%20chef%20dryer&rls=com.microsoft:en-us&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&sa=N&hl=en&tab=wv#
Posted on Sep 20, 2009
It sounds like the spring in my washer has broken. It made a loud sound during a cycle and now the basket is completely off balance and barely moves. I was wondering if the spring is worth fixing or if...
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem. Pull the unit out from the wall and removed the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broke you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. The belt is easily replaced once you know the below procedure:
1. Place the belt around the center of the motor pulley stretching the belt to the spider pulley leaving no slack in the belt.
2. Keeping the slack out of the belt, place the belt on the outside rim of the spider pulley as much as the belt tension will allow you to do so.
3. Keep the tension on the belt and slowly rotate the spider pulley counter clockwise until the belt is completely on the spider pulley.
Rotate the spider pulley several times to make sure the belt stays in the center of the spider pulley. If the belt is not centered after several revolutions you need to remove the belt and reinstall it after moving the ribs of the belt on the motor pulley in the direction which centers the belt. If it was my unit I would fix it unless you have to replace the outer tub shell (approximately $300.00 for parts only).
Feb 18, 2011 | Stainless WSXH208AWW GE Extra-Large...
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
THE SPIN DRYER IS MAKING NOISE BUT NOT SPINNING
Hi, if the tub is not spinning, you have either broken the belt, or the motor has burned out. If you are a handy person, you can pull off the back panel to get a look at the tub and the belt will be wrapped all the way around the tub and motor pulley. Turn it on if the belt isn't broken to see if the motor is trying to turn at the pulley. If the belt is broken that's the problem, but also make sure the motor runs because if it if froze up due to loss of bearings it will break the new belt if you decide you are going to try and replace it on your own. You will have to wrap it around the tub and run it over the belt tentioner and around the pulley. You can get a belt at a appliance parts house. Take the model, serial, numbers and brand name, and the old belt may have a part number on it. Keep me posted please.
I will check back in the morning.
Sincerely,
Shastalaker7
Mar 17, 2010 | Washing Machines
Will not spin
make and model number for accurate diag, but most common problem is broken wqasher tub drive belt, turn washer on its side and check for a broken belt.
Sep 27, 2009 | Washing Machines
How do i fix the tub from not spinning
You did not say if it was broken or not...
If it is broken then it must be replaced.
If it is not broken, then it must have came off the pulley or the drum.
you have to pull the front of the dryer off and remove the drum to reinstall the belt on the pulley and the drum
Sep 25, 2009 | AEG Dryers
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Kenmore Front Load Washer Drive Belt Keeps rubbing up against Tub
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Tub won't turn
hi, it sounds like your drive belt is broken! all you need to do is remove the back panel to replace the belt its quite easy no need to touch the motor, hope this helps
Feb 21, 2009 | Washing Machines
Broken belt on a Whirlpool dryer
Fix it yourself, and you do not need to remove the tub. Put the belt around the pulley and pull the tub towards the belt. You may have bought a belt that is too short. But upon a belt breaking they will stretch pretty bad also
Jan 13, 2009 | Amana ALW480DA Top Load Washer
Need to know how to replace belt on kenmore front loading washer
Please first check if belt is broken? If not How old is the unit?
Jan 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Magic Chef Washing Machines Experts
shaun taylor
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
