Question about MSI X58 Pro Motherboard
Msi x58 pro beep codes
Msi x58 pro beep code, computer not booting, need to know what the beeps mean
    Scholar:
  • 74 Answers
If you have a way to get online, then google in Computer beep codes, this should help you out.
Posted on Sep 20, 2009
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
You will need adobe reader, to read the content.
Best of luck
Mar 23, 2013 | MSI Computers & Internet
I have a used HP/Compaq dc5800. I reinstalled win xp pro to clean out HD. When finished I noticed the computer did not recognized the ethernet card, sound card and graphics which are all integrated. i...
You would need to look at the BIOS manufacturers site for the beep code and it's meaning. You can also pull all the hardware out, memory HDD, CD/DVD and boot if you no longer get the error, power down and add one component back and boot. Repeat until you get the beep code again and you will know what the problem part is.
Oct 08, 2012 | HP Compaq DC5800 Small Form Factor PC...
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
Getting 3 beeps on my MSI 870-G45 motherborad
If they're happening during POST (After the bios screen loads but before the OS boots), it could mean a memory error. Also, it can depend on the length. If they're three short beeps, it's the memory. Long and short combinations mean different things as well. You can find a good description of different beep codes in the source.
You can verify a memory error using memtest86+. It's a burnable ISO you can easily find on google. Turn it on and let it go and it will let you know if any tests fail. If they do, it could just be one of your cards. Try taking one of the cards out and turning the computer on to see if it still beeps. If it does, switch cards. Also try putting them in different slots. Usually the combination of switching cards/slots will let you know if it's a bad card, or a bad slot.
Source: http://ec.transcendusa.com/helpdetail.asp?Help_No=70 - beep codes
Everything else is experience :)
May 28, 2011 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
Computer will not boot. Beep error code is 2-2-3. Problem? Motherboard is micro star MS-9121 in an ibm intellistation
Hello the download site is here:
http://www.msi.com/product/server/E7505-Master-L-Series.html#/?div=Driver&os=XP%2032
Here you find the manual:
http://www.msi.com/product/server/E7505-Master-L-Series.html#/?div=Manual
Please select your windows system.
And unzip the file before you can use it:
A 1-2-2-3 beep code pattern means that there has been a BIOS ROM checksum error. Literally, this would indicate an issue with the BIOS chip on the motherboard. Since replacing a BIOS chip is often not possible, this Phoenix BIOS issue is usually corrected by replacing the entire motherboard.
More codes here:
Good luck
Dec 20, 2010 | MSI E7505 Master-LS2 (MS-9121) Motherboard
MSI Motherboard: weird beep code, doesn't work with graphics card
The beeping that you hear are bios codes. These codes are designed to tell you what is wrong or at least point you in the right direction.
It is helpful to list the bios that you are using so that you can find the codes for your bios. here is a site that could be usefull to you and one of the codes that you mention say to reseat the ram or replacing the CPU.
http://www.pchell.com/hardware/beepcodes.shtml
Nov 08, 2009 | MSI KA780G AMD780G Socket AM2+ Motherboard
MSI X58 Pro  Motherboard Logo
1,056 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
