Question about Kenmore Washing Machines
Hello, I am trying to open my washing machine to check the pump, because it is not draining well at all. My wife washed bathroom rugs and the rubber bottoms disintegrated into small particles that may have clogged the pump. what tools do I need?
  • 1 more comment
  • crukuba Sep 20, 2009
    IT IS THE 90 SERIES
    Is there someone working on my problem?
    kenmore 90 series
    what tools do ineed to open to access the pump?
  • 15,935 Answers
You need a screwdriver :D - and a little know-how.
Check out this video on accessing the pump in a top-load washer.
If you have additional concerns - please use the "Continue With This Expert" option so we are connected in the future.
Thanks!! :)
Posted on Sep 20, 2009
    Brigadier General:
  • 3,614 Answers
What is the exact model and maker of your washer?
Thanks
THE WASHING MACHINE WASHES THE CLOTHES BUT WHEN IT COMES TO "SPIN"THE MACHINE STOPS. SPIN ICON KEEPS ON BLINKING.
Check your drain pump. It is on the front lower side of the machine. There is a small door which opens to it. Unscrew the filter and the pump cover. Be careful when you do this. There is a small drain hose next to it. Use this hose to drain to a pan before opening the filter lid.
Aug 16, 2014 | LG Washing Machines
Washed a small bath rug in the machine. The piece of rug said it was washing machine safe. The rug broke apart as I was washing it and now the washing maching will not drain. I have to open the bottom...
This becomes a long drawn out process in which you have to remove the pump and the entire drain line and wash all the backing out of the machine also you have to remove the lines that go from the tub to the pump as well and even after you finish cleaning out the drain system you still will have more pieces stuck inside the tub area that you have to clean out as well. Easiest way take the machine outside or to an area you can use a hose on the unit where after you disassemble the entire pump area that you can wash the tub out of all the small pieces of the rug backing I had the unfortunate repair of doing this to someones rubber backed rug cept it took all the rubber off the back of the rug. It took about 3 hours with hooking and rehooking the drain lines and unclogging them over and over due to this unit I was working on was in a basement and no access to a hose If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
p.s do this repair yourself a repair technician would charge about 200 to repair the unit due to the amount of time
Apr 28, 2011 | Samsung Washing Machines
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
F02 error code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
Jul 24, 2010 | Kenmore 42822 Front Load Washer
Washer not draining
sorry about this problem,we get this alot your drain pump is clogged,so try this take cloths out and see if you can scoop out water.Now put rooto-roter drain opener in drum and let it sit for about 1-2hrs.Now run on heavy-duty by itself it may have to go through 2 cycles,to clear out clogg.See the drain pump is real small,so dog hair,strings,or pieces of rubber from throw rugs well clog pump.So first try this.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag mah4000 washer
My machine (Maytag MAH4000aww) failed to drain because of a bobby-pin that was lodged in the drain pump impeller. Because of the added weight of the wet clothes, and the undrained water; the machine would not spin. The Wax motor worked as the door did lock properly, but the machine would "ramp up" trying to spin, but would stop the process when it sensed that the load was grossly unbalanced. Check the drain pump to see that it is not clogged or that the impeller is not impeded by a foreign object before spending money on imbalance switches! I will now cancel the service man, who surely would have charged me for a new pump, plus the cost of the visit, and now I can stop swearing! My wife is glad she married me!!!!
Rene Marchand (Beaumont Alberta)
Jan 13, 2008 | Washing Machines
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
