Question about Nintendo Wii Console
The console will not power up. there is a game in the drive.
  • 53 Answers
Check all the cords in the back of your wii and plug cords on diffrent outlets on your wall
Posted on Sep 22, 2009
Green flashing light on power button what does this mean ?
This indicates that the console is looking for the
CD rom drive . The drive may not have fully closed
fully to activate the open/close switch inside.
First press eject with the console off load a game
and see if that helps .if not remove the game and
try again.
Give that a try.
And let me know how that works .
Rob
Aug 19, 2010 | Microsoft Xbox 360 Console
Tip
How to jailbreak your ps3 (backup and play homebrew games)
How to jailbreak PS3(PlayStation 3)? chips available at www.ndsireland.webs.com
Follow the complete step by step guide posted below to jailbreak your PlayStation 3 to enable you to create backups of original discs.
Pre-requisites are as follows:
* Any (FAT or SLIM) PlayStation 3 Console running firmware 3.41 or above.
* PS Jailbreak USB Modchip.
* An external USB drive formatted to FAT32 with the "Backup Manager" file on it which you can download from here.
* Original disc of any PS3 game which you want to backup.
Step 1: Power off your console and make sure that there isn't any disc in the Blu-ray drive.
For the SLIM Model: Remove the power chord before plugging in the USB.
For the FAT model: Turn off the power switch found at the backside of the console.
Step 2: Now insert the USB based PS Jailbreak Modchip to any USB port of your choice on the console. Once the USB is in place, Power ON the console and immediately press the "Eject" button. There should now be two LEDs turned-on on the USB as the console is loading.
If the LED light on the USB turns green, you are good to go as the PS Jailbreak has been successfully loaded.
If the LED turns red, then it means that the PS Jailbreak Modchip didn't load successfully. This usually happens when the Power and Eject button sequence wasn't performed properly. Start from Step 1 again if you end up having the red light.
Step 3: Once the console has finished booting up with the PS Jailbreak Modchip, plug-in the external USB storage device which has the "Backup Manager" setup to the console's USB port.
Step 4: Now navigate to the "Game Menu" and select the option "Install Package Files" and then select "manager.pkg" file. This will basically install the "Backup Manager" application that you download earlier to your hard drive.
Step 5: When the "manager.pkg" file is done loading, scroll all the way down in the "Game Menu" and there you should see a new application called "Backup Manager", run it.
Step 6: Now we're in the Backup Manager app. Insert the game in the console's optical drive which you want to backup. Press "O" and you will be asked where to make the backup, on the internal HDD or the external storage source connected via USB. This process is further elaborated by the following screenshots.
Step 7: In order to play a game via the backup you just made, insert any original game disc into your console (To emulate the loading process), run "Backup Manager" in the "Game Menu". Press "X" to play the selected backup game.
Step 8: Now you will be taken back to the main menu. In the "Game Menu" you will see the game which you have backed up. Now you can select the game, and run it without having the disc in the console's drive.
Oh and you must make sure that the PS Jailbreak USB Modchip is connected to your console at all the times when you are playing the games via backups.
Disclaimer: This guide is for educational purposes only. I'm not responsible for any loss of important data or malfunctioning of your Game Console.
on Oct 06, 2010 | Sony Playstation 3 (PS3) Console
Games wont load. It has an
The disc drive has gone bad, you can replace the drive or get the wii modded and play games from a hard drive. Get it modded free from www.wiihdmods.com and get 100 wii games playable from a hard drive for 150.00
Apr 19, 2010 | Nintendo Wii Console
PS3 has a game stuck in drive and won't power up
look up YLOD and see if thats your problem!!
To get the cd out the trick is to turn the ps3 off from the back!!! hould down the eject and turn it on from the back.. this will kick the fans on high then spit the cd out.
Let me know if you got your game out,, and if you have ylod i can help more if needed.
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Hello, when I put a game in the screen says, open tray. Wont reconize any games.
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Mar 20, 2010 | Microsoft Xbox 360 Console
Think i turned the power off wrongly, now my games wont work
power shouldnt have anything to do with that besides maybe surging the blu-ray drive, your best bet is to get a new drive and see what happens
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
E68 comes up when powered up
This is a hard drive error, take off your hard drive and see if you can play a game without it, if this works turn off your console and re-attatch the hard drive to your console, if this does'nt work it is either a problem with the hard drive its self so test in another console if you can, or an internal connection problem to the hard drive port.
Hope this helps.
Jan 17, 2010 | Microsoft Xbox 360 Console
Comes up couldnt find hard dive
turn off xbox unplug pwer supply disconnect hard drive, wait 1 mintue. connect hard drive connect power supply turn power on.. if same problem disconnect power supply disconnect hard drive. connect power supply insert disc if game plays without any problems you might have a bad hard drive .(800) 4MY-XBOX
Oct 12, 2009 | Microsoft Xbox 360 Console
Hard disk
remove your hard drive, power on teh console, power off the console, install the hard disk again and power again the console.
Hope this will make the system recognize the hard drive again.
Sep 01, 2008 | Sony Playstation 3 (PS3) Console
The tv said that the game had a problem and at the bottom of the screen it says E 68
Try unplugging everything connected including power and video inputs and your hard drive/memory card from your game console then plug them all back in and boot up. If that doesn't fix it, then you need to replace your hard drive.
Apr 17, 2008 | Nintendo Game Boy Advance Console
Nintendo Wii Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
