Question about Air Tools & Compressors
Coleman Powermate Inflationmate portable 4 gallon compressor. Model VP0200406. See image at http://www.yotatech.com/f5/how-fix-compressor-111315/ . Coleman lable on back says 120 v, 15 amp, single phase, 95-125 psi, 60 hrz. Anyone know what size fuse to use? Have been to 100 s of websites and can't find squat. Thanks. Keith
  • cwmoss Sep 21, 2009
    Thanks for the quick response.
    One of the Coleman/Powermate/Sanborn/MT websites has a long list of model# service diagrams but the one that pops up for this model # looks completely diferent.
    At least the fuse isn't blowing and the power light is on. Only 56 volts across the fuse holder and about 16 volts across the two leads to the pressure sensor. Time to tear it apart and find out where the 120 volts stops. Maybe I put it back together again and maybe not.
    Thanks again. cwmoss
    President:
  • 1,723 Answers
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
Posted on Sep 20, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
I got me a compressor but do not have any info on it
All of the manuals (user and parts) for all of their products are at:
Assuming that you have the ILA3606056 - Owners manual direct link is:
http://www.powermate.com/pdfs/2007/11/29/manual_operators_manual_single_stage_cast_iron.pdf
Hope this helps, if so please leave feedback .. if not pls let me know and I'll try and help some more!
Feb 02, 2010 | Coleman Powermate 60 Gallon Air Compressor
Coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Jan 10, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Sep 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
497 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
