Question about Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
I have a Hotpoint WT960. After each wash there is always water in the fabric conditioner side of the the detergent drawer. Can you tell me what causes this please.
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Posted on Sep 22, 2009
  • Hotpoint Master
  • 744 Answers
Hotpoint WT960 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Jul 30, 2013
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Why doesnt the fabric conditioner dispenser empty after each wash?
The softener dispenser is flushed with water as part of the wash cycle. The residual water prevents softener from clogging the dispenser between was cycles.
Aug 01, 2014 | Hotpoint Washing Machines
Hotpoint washing machine WT960 is flashing F-12
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODESAccording to hotpoint website
Nov 26, 2011 | Hotpoint Washing Machines
Hi my wt960 leaks from the front of the machine. Usually on rinsing or spinning. It really has me baffled had it apart several times now. The filter is all clear. Does appear that the draw fills up alot...
I get this a lot on our Hotpoint WF860. The problem is that the drain pump is blocked by a bit of sock / breast pad / coins / hairbands etc! It is easy to fix by removing the hose which leads from the drum to the pump. I expect the problem will then be obvious if you look inside the pump.
Jan 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
THE FABRIC CONDITIONER COMPARTMENT ON MY BWM129 WASHING MACHINE IS ALWAYS FULL OF WATER CAN YOU TELL ME WHATS WRONG
Hotpoint BWM129 This video will show you how to keep your soap draw clear and how to service the parts
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2010 | Hotpoint Washing Machines
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint ultima 7KG WT960
The detergent/conditioner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 12, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
862 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
