Question about Garden
I have a Clarke PLS160AH and it has just started leaking water from the back of the pressure guage (through the hole in the back of it) also from the underside of the guage, also the guage is filling up with water and when the trigger is pulled on the lance the needle on the guage goes off the scale
  • 68 Answers
SOURCE: LXGH E5 Code
I need to check my codes to be positive. And I'll check them this weekend. But, I believe E5 is from excess water in the unit, and so it won't go into rinse and add more water.
First and most common -- the drain hose, at the back of the unit is kinked. The unit gets pushed back against the wall and kinks the line.
Second, your probes are dirty. The ones in the back right corner detect water level. Clean them with a green scrungee even if they look clean.
Good luck - Mike
Posted on May 10, 2008
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 92 Answers
SOURCE: I have an old kew pressure washer and when I pull
Dear dennis_partr,
In general all pressure washers have a control valve. This is sometimes refered to as the Spill Valve. When the trigger is pulled, the spill valve is in normal position. When the trigger is released, the spill valve compresses to let water circulate from its bottom part. If when the trigger is pulled and the bottom part of the spill valve does not close, then water keeps on circulating and hence no pressure. In this case change the spill valve with a new one. Also there could be a fault in the sucktion valves. If the sucktion vaves do not close, also water keeps on circulating. One also can examine the delivery valves. If these are not closing, then water is being sucked while delivering. Hence no pressure. Another cause but very rare, is that the swash plate that is pushing the pistons got loose. The electric motor will be turning, but the pistons stay in the same position.
I mentioned many causes, but usualy it is the spill valve. If with a new spill valve, there is still no pressure....then you must tackle the sucktion and then the delivery valves.
I wish to add that I assume that you have the correct lance and correct nozzel size. A worn out nozzel, will result in low prssure too.
Regards,
Fulltech.
Posted on Apr 22, 2009
SOURCE: Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
Posted on May 19, 2009
  • 251 Answers
SOURCE: We have a Karcher G2500VH pressure washer. If you
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Posted on Mar 08, 2010
Why isnt the pressure gauge moving?
urn system off unscrew pressure guage clean out hole then put back in then turn on should work if not bad guage also turn on without guage to see if it spits water
Jul 10, 2014 | Hayward Pool & Spa
Have a oldsmobile alero that over heats every 5 to 10 mins, always have to pull over. Thinking there might be a pin hole in hoses that enlarge under pressure, do not see any coolant leak at all. Think
Might be the thermostat or could be a cracked head! Check your oil for water! And you can buy some stop leak from like auto zone or other parts house
Jan 14, 2013 | Cars & Trucks
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
PANCAKE COMPRESSOR WON'T SHUT OFF AND WON'T BUILD PRESSURE.
most likely the regulator is shoot. But also try checking for leaks with dish soap and water in a spray bottle.
Mar 06, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Water leaking in from freezer into main refrig at the back
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jul 05, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Leaks coolant were could it come from
If you don't know where it is coming from, you have to find that out. Check the location of the spot on the floor, if you don't have a floor, put down a piece of cardboard, locate the drip, then look under the hood for what it is that is leaking. It could be the overflow on the expansion tank, could be your AC condensate line dripping, could be one of those tiny coolant lines that return to the back of the engine, could be the water pump, could be a hole in a hose. I don't know why the pressure check didn't show anything, might be something else. Check it out.
Mar 05, 2010 | 2006 Chevrolet Impala
92 Corona auto - fill radiator with water - drive 90 minutes did 150 k no serious hills- temperature guage needle moved up after moving from 100 k to 50 k - no water - temperature guage just about in red -...
sounds like a coolant hose has a pin-hole or burst slightly open. pressure test cooling system or if you do not have a tester ----fill system with water and with bonnet open run engine untill it gets hot, builds pressure and starts leaking ,just keep an eye as where it leaks,
Dec 20, 2009 | 1992 Toyota Corolla
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
Reply for bogging maxima
how big of a hole did he drill?
it would have to be very large unless you put a guage in the hole and checked the back pressure
Sep 25, 2008 | 1995 Nissan Maxima
Garden Logo
47 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
