Question about Mitsubishi Televison & Video
Lamp light is red on my WD-57831. Sometimes turning tv off for a little while works, but other times it goes out again... I have company coming to watch a game next weekend and don't want to risk it going out again, but don't want to replace the lamp unnecessarily. I also moved recently and am wondering if something could have happened in the move?
  • cat47474 Sep 20, 2009
    Yes, the issue started after my move - which was about a month ago. So I'm not sure if it's the catalyst or not.
    I opened the panel and did not see anything - though, admittedly I don't know what I'm looking for. However, with the exception of when I checked the panel, I've had the tv on for almost 2 hours now without issue. Do you think yesterday was a fluke? Is there any setting I can check to test the lamp life? It was replaced probably about a year ago.
    Thanks for the assistance.
    I will check for loose circuits. thanks
  • 10,594 Answers
Please check connectors on circuit boards and mounted circuit boards on main board of TV that can be loose / misaligned during move, press connectors and boards just to make sure all are intact properly.
Also check lamp door (first part of lamp housing in TV) that should be fixed securely in its position as you said lamp was replaced once.
Lamp consumption time reading would be available in firmware of TV but it is tech job to go into service mode to read out lamp hours. I would not recommend any user to go into service mode because any wrong button push can mess with TV data.
Thanks.
Posted on Sep 20, 2009
    Guru:
  • 1,326 Answers
Its quite possible if it was not moved gently. Did this problem occur before the move or only after? If after then its very possible that a slight bump or rattle could have shaken something loose (hopefully not broken it). You can do a quick spot check by opening the rear of the set (unplug power first) and look for any lose connection or componets that look out of place. Make sure you be very careful of the electrical circuit as tv's have series of capacitors that will hold residual voltage up to 48hrs after unplugging and can cause a mild shock if you touch them.
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red...
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Oct 03, 2010 | Mitsubishi WD-60735 Projection Television
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv doesn't work
If this TV has a lamp it could be it. I need the model number to better figure it out
Mar 08, 2010 | Televison & Video
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
