Question about Garden
Lawn tractor stalls
When I let the clutch out, even in neutral, or engage the mower deck the tractor wants to stall.
    President:
  • 986 Answers
Sounds like you have carb jet dirty,remove you bowel on the carb with 7/16 or 1/2 wrench remove the bowel and clean out. make sure you float works up and down freely reinstall bowel and start that should get you going ,I hope this help you.
Posted on Sep 20, 2009
Sears 21 h.p. lawn tractor
Sounds like a safety interlock. Was there any electrical wires going to the deck, to the engage switch, the up down lever? There is a neutral switch that is closing or opening and the circuit is shutting down the motor.
Feb 08, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 1998 briggs and stratton ride on lawn mower and when i let off the clutch even in neutral the mower stalls
here is what you do. remove one spark plug and start it up. if it runs reinstall it and remove the other plug and start it up. if it runs on one plug, but not the other, you have a set of bent valve push rods and you are actually running on one cylinder which causes that stalling and no power even though it sounds good. push rods are cheap and easy to replace, but you should leave the fine adjustment to someone who knows what they are doing, and do both sides. common B&S problem.
Mar 20, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor starts and runs fine, but if I let out the clutch (even in neutral) or try to start the mower deck it dies.
I'm going to take a guess at this one. If I'm not on my seat and try to do either of those things, my machine stalls.
Check your seat safety switch.
Dec 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere tractor stalls when I let up on the clutch.
when you let the clutch out and it stop engine it could be a safty switch. but a safty switch would not make it stop after it was runnig unless you have a short in the wire.
Jul 06, 2009 | Garden
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
