EPSON DX4050 PRINTING BLANK SHEETS, NO ERROR MESSAGES, PAPER, INK, NOZZLE, CABLES ALL CHECKED. TRYING TO PRINT FILE FROM M/SOFT WORKS AS USUAL, NO GO
  • 511 Answers
Problem with electricity to head. It's usually caused by short circuit at head, cause of ink leakage. If you have experience with electronic circuit, check voltage output at wire to head, check small circuit at carriage. Then check the electricity at printer mainboard especially at fuse. Find this reference at aicaxz's solutions for same problem.
Posted on Sep 20, 2009
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I have a Epson Workforce 600 printer. Changed all ink cartridges and cannot get the black ink to print. It will print in color mode only without the black ink. What should I do? Sandy
Hello Jaasp,
Follow these steps to print the nozzle check:
  1. Load a few sheets of plain paper in the sheet feeder.
  2. Press the Home button.
  3. Press cp_button_41_er.gif or cp_button_42_er.gif to select Setup.
  5. Press OK.
  6. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance, then press OK. You see this screen:
  8. Select Nozzle Check, and press OK.
  10. Press cp_button_6.gif Start to print the nozzle check.
  11. Shown below are some examples of what the nozzle check may look like.
    Nozzle check pattern with no gaps
    Nozzle check pattern with gaps
  12. Press Finish Nozzle Check and press OK when you're done.
Jun 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
My epson 1400 printer doesn't print
try printing a nozzle check to see if the nozzles are clogged by dried inks that why nothings printing. turn off the printer than press and hold power and paper button together for 3 sec. then release, it will print, if blank, all nozzles are clogged. do a head cleaning. hold the ink button for 3 seconds. wait until the power light stops flashing then print nozzle check again until all lines are complete,
Feb 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
113 people viewed this question
k24674
jasbo
jasbo
