Question about Bosch Dishwashers
Bosch dishwasher leaking clean water
My Bosch dishwasher is leaking a small amount of clean water which I have to wipe off the floor a couple of times a day.
I tipped it up to look underneath and more water leaked out. It seems to be gathering under the metal bottom of the appliance and overflowing in the front left hand corner. Any suggestions would be helpful. The dishwasher is 15 years old, so unless there is a really simple fix, I will consider replacing it.
Thanks
Mark
  • 1462 Answers
SOURCE: Pin hole leak in metal under dishwasher
difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Posted on Apr 12, 2007
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
SOURCE: dishwasher leaking around the bottom of the door
We just had the very same problem and sure enough a flexible cutting board was over the outlet...very strange but thanks
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Posted on Mar 16, 2008
SOURCE: hear the motor running, no water in dishwasher
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Posted on Feb 08, 2009
Bosch Dishwasher SMS40A08GB Silver Edition. Check Water light comes on but no error codes.
The unit may have developed a leak underneath and it may have a bad heater element. Pull the unit forward and put towels behind it on the floor, tilt it back 45 degrees to drain the water, wipe up the excess and put it back in position. Test it.
Apr 30, 2018 | Bosch Dishwashers
How do I fix this problem? When I start the dishwasher, it runs for a minute or two, then stops and the "Clean" light comes on. So far, I have replaced the control panel, the power module, and the Hal
If you pull up on the float and the water burps a couple of times and does nothing else, then your drain pump is bad. It is doing a rinse of the inside before it adds the detergent, if the drain motor is bad it will simply let this small amount of water in the bottom and adjust the indicator to clean. I have had this same issue with mine. One clog and the motor goes kaput.
Jul 27, 2014 | Bosch Dishwashers
BOSCH SHE43RF5UC fills with water during off periods
You are correct. The inlet water valve is leaking. It might be worn or have debris stuck in it. There is a very small chance that the electrical signal from the controller is letting a small amount of current in and holding it open. To rule out this problem you can uplug the machine and see if it stops filling. Otherwise just replace the valve. IT is not hard to do.
May 22, 2013 | Bosch Dishwashers
Bosch exxcel auto option - Have not run it for a couple of months. Turnit on al all it does is pump out
The usual reason for this is that water hes leaked into the bottom of your dishwasher under the washing compartment. This has caused the float to rise and trip the switch which activates the Aqua-Stop / anti-flood protection system. This also closes the solenoid (water control valve) to stop water entering this dishwasher. You may already have had a small leak before you stopped using it.
The only way to check this is to remove the washer from under the counter (disconnect power and water supply first) and tilt it backwards about 15-20 degrees. Water should run on to the floor from under the washer so I suggest putting some old towels down first. Once the water has been drained from under the washer, you can use it again, but it's not advisable if you have a leak and this really needs to be investigated.
If there is no water from under the washer, you may have a faulty float switch or possibly a faulty control module.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Bosch Dishwashers
Leaking water.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
nnb
Jun 05, 2010 | Bosch SHU9915UC Dishwasher
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Mar 03, 2009 | Bosch SHU9915UC Dishwasher
Hear the motor running, no water in dishwasher
Feb 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
