Howdy, I am running Vista Home edition & I am hunting for a simple HDD temperature program that runs in the tray giving a constant reading. All I am able to find are more complex software,so all suggestions are really appreciated.
    President:
  • 2,678 Answers
All that and more with this
http://www.ntfs.com/disk-monitor.htm
Posted on Sep 20, 2009
Testimonial: "Terrific.Many thanks for you trouble."
  • Alun Cox Sep 20, 2009
    You're welcome.
What do I do if the Yamaha 350 warrior won't start by the button but when you jump start it, it runs fine
HOWDY howdy DaleBohn,
Well... I dove into this thinking it was an ATV.. but conventional CYBER wisdom lists more "Warrior" bikes than it does EVERYTHING else.
Macht nichts: Check for a fuse between the STARTER Switch
and the SOLENOID/Relay... Most common source for the constant battery "B" LEAD is THE SOLENOID/Relay..
Before EVERYTHING Else: check for fuse.
Then... the easy FAST (likely) way is get 3 prices on YOUR starter Relay/Solenoid... Buy one and put it in... If that fails...
(Store GOOD STARTER solenoid (you always wanted)).
then buy a VOLT METER and get all scientific...
To wit:
The point of this operation is to determine why the battery...
With your new VOLT-METER and possibly an assistant
(if your arm is not long enough) ...
You are going to operate the MOMENTARY starter switch...
During operation you should see 12V battery on both wires...
(Battery & Start) Means switch is good switch...!!
"B" terminal having constant battery = GOOD
(else: fix battery wire to START switch (not likely)).
"S" BATTERY only when start is active = GOOD
(else: replace switch (not likely)).
Happy hunting... https://www.bing.com/search?q=Yamaha%20350%20warrior%20START%20RELAY&qs=n&form=QBRE&pq=yamaha%20350%20warrior%20start%20relay&sc=0-28&sp=-1&sk=&cvid=AAC1F04D31A045D890DDA5B038C42C14
Mar 18, 2016 | Yamaha Motorcycles
I can't download iTunes. I'm using windows vista.
Right click the iTunes install program and click "Run as an Administrator". This will give you full access. Letme know if this works!
EDIT:
What version of Vista are you running??? (eg Home Premium x86 or 64bit, etc.) and also, is your account a Limited or Administrator???
EDIT 2:
Also, have you installed Quicktime or iTunes ever before on your computer with Vista??? If you did, you have to login to the account that installed it before.
EDIT 3:
Vista is really weird with quicktime and iTunes., so basically your problem is that you have to be on the user name that installed quicktime, using the "Run as Administrator" option. Ive seen this before with Vista and it has to do with ownership permissions.
Dec 01, 2010 | Computers & Internet
If the cd drive cannot detect while inserted
Hi, friend,
In this case, simply run the Microsoft Fix It utility : it is an automated utility to run and it will automatically diagnose and repair problems with your CD or DVD drive when trying to read or burn media.
click on the foll. link
http://support.microsoft.com/gp/cd_dvd_drive_problems
and read the simple instructions there, and click on "Run now" on the top right of that page and run the simple utility, then reboot your computer.
This utility takes care of problems with your CD or DVD drive when trying to read or burn media, in 90 % of the cases.
Try it !!!
Oct 01, 2010 | Microsoft Windows Vista Home Basic Edition...
Does Avid Liquid 7 support Vista Home Premium
Avid Liquid 7 is an video editing and authoring software created by Pinnacle Systems.Though they have mentioned support for only Windows XP, it is possible to use Avid Liquid 7 on Windows Vista and Windows 7. Tip is very simple. You just need to run it under compatibility mode. To do this
  • Right Chick on Avid Liquid 7 Shortcut
  • Open file location
  • Right Click on exe file
  • Properties
  • Click compatibility tab
  • Tick mark 'Run this program in compatibility mode' and choose Windows XP (Service Pack 2)
  • Apply and run the software.
Sep 28, 2010 | Avid Liquid Pro 7 for PC
Pocitrac pyta ovladac na hdd
>> po?íta? ?¾iada o ovláda? pre disk
> Computer asks for driver for HDD (hard disk drive)
Slovakian? Slovenian?
Windows 2000 & XP & Vista & 7 _include_ the necessary device-drivers for HDD devices.
Sep 24, 2010 | Microsoft Windows XP Home Edition
Is Calendar Creator v12 compatible with Windows Vista. System Requirements on pkg reads Windows XP (Home & Pro), SP3.1, Pentium II 300 MHz processor faster, etc.
Greetings,
It's my best understanding that it is not compatible with Vista. Were I you, I'd do a search something like "compare Calendar Creator 12 to" and review some of the programs that would pop up to see if any of them look like a possible solution. Also, you might want to make sure they'll run on Windows 7 toward the chance of a later upgrade on your part.
It might be of interest for you to know that W7 Professional or Ultimate Editions come with the opportunity to download (free) their XP Compatibility Mode software which will allow you to run any XP program that is not scheduled to be formatted for Vista or 7.
Regards,
Marcus
Sep 12, 2010 | Dell Computers & Internet
Howdy, I'm Running vista 64 bit Home Premium. I downloaded the 1.05 version for vista from the alesis website. after installing it i get a "fstConnect.exe-Application Error. The Application failed to...
Use Add/Remove Programs to remove that '1.05' version.
Visit the ALESIS web-site, and click on "get support",
and tell them that the '1.05' version does not work with 64-bit Vista,
and ask them what they recommend.
Oct 27, 2009 | Alesis FirePort 1394 (ALEFP1394)
Start up
Do you have many softwares installed? If so disable starting those programs during start up. Try "Advanced System Optimizer---vista edition" for tweaking your OS and PC...sodeep
Apr 24, 2009 | Computers & Internet
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
Fullscreen mode using turbo c in windows vista
try to download the turbo c in vista go google it email me i'll give you the link ronaldsuboc@yahoo.com
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
157 people viewed this question
Alun Cox
David Payne
David Payne
