Question about Maytag Washing Machines
What problems with Maytag washer Model # MAVT236AWW
Can you tell me the main problems associated with Maytag washer Model # MAVT236AWW? I'm considering buying a used one.
4 Suggested Answers
  • 86 Answers
SOURCE: Maytag SAV washer leaking all over floor
I have the exact same washer with the exact same problem. I have a home warranty that covers appliances so when they sent out the Sears technician, he took a list of parts and replaced about 9 things for a grand total of $450. If I didn't have a home warranty that only charged me $55 to do it, I would have just bought another non-Maytag washer.
Posted on Jan 23, 2008
  • 6277 Answers
SOURCE: clothes come out very wet.
This sounds very much like the motor is failing or the belt is slipping. Motors- and belts, which is sensible to change at the same time- are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts, normally 2, should be loosened and the belt removed then remove the bolts completely
With the motor it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished. Refurbishing includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit firmly on the commutator but straddle it- the centre is often more worn than the outer part.
Unfortunately motors are not cheap- the motor for our 18+ yearold Bosch cost GBP250 but it will probably outlive us! It's your choice obviously.
Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 20, 2011
heatman101
  • 43501 Answers
SOURCE: Maytag washer model # MAVT236AWW
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 20, 2011
I have a maytag washer model mavt236aww. It began making noise during spin cycle. I suspect bearing going out. Now it is also leaking water from above transmission. I bought a bearing and seal kit. I have...
you may need heat from a paint remover gun in order to loosen the grip on the shaft and you will need to take a flat screwdriver to get behind the seal to remove it press th new seal in evenly otherwise it wont seal properly maybe a friend from a garage could help eric
Dec 29, 2017 | Maytag Washing Machines
Maytag mavt236aww works on delicate but not on normal. when in normal position the washer will fill up, but will not agitate or spin out or drain
Possible that the controller unit is a suspect.Check the INLET flow , check the INLET valve, Check if water fills, If not there are errors in the program output and the controller could have memory issues.
Jan 24, 2013 | Washing Machines
My maytag washer mavt236aww will not turn on
Check to be sure the lid switch was hooked back up. It is easy to overlook.
Nov 10, 2012 | Maytag Washing Machines
My Maytag top load washer model # mavt236aww seems to stick on the rinse cycle. along with that the cold water does not shut off, it continues to fill the drum and overflows. Please help.
This is symptomatic of a malfunctioning cold water control valve. Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 11, 2011 | Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
heatman101
Apr 20, 2011 | Maytag Washing Machines
My maytag washer mavt236aww when it spins all the water does not come out
heatman101
Apr 14, 2011 | Washing Machines
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Jul 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytag MAV5920EWW and i need to know how to get the agitator off as well as the front panel
Hello there:
here isa couple of links below that will show you how to do it ok
I hope that this is very helpful for you
Best regards Michael
  1. [PDF] 16026502 Maytag Amana Top Load Washer 8628k - Adobe PDF - View as html MAV5920EWW. MAV551EEWW. NAV8805EWW. Electronic. Energy Star rated. ... "Agitator/Spinner/Outer Tub/Transmission Removal" procedure. ...www.servicematters.com/maytag_library/docs/16026502.pdf
  2. [PDF] Technical Bulletin 1950k - Adobe PDF - View as html MAV4758AWW, MAV551EEWW, MAV5758EWW, MAV5920EWW, MAVT236AWW, MAVT346AWW, MAVT446AWW, MAVT546EWW ... 4. Remove Agitator by loosening bolt threaded into ...www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Nov 22, 2009 | Maytag MAV5920E Top Load Washer
Washing Machines Logo
899 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
