Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Tv turns off and on repeadly
Green led flashes. seems like the tv is restarting every 5-10 secs. tried to reset tv, checked all connections and checked bulb everthing seem to be good. once the tv did not start back up and the red led blinked 5 times.
  • Anonymous Dec 16, 2007
    When turned on the green light flashes and then the redlight flashes every three seconds but no picture.
  • rwhite Dec 20, 2007
    replace ballast for bulb - did not fix problem
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
If bulb is ok and this is a DLP the ballast that fires the bulb could be bad.
Posted on Dec 14, 2007
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dead. LED changes from green (around 8 sec) to red (1 sec), not flashing.
You need to check the connection stripe inside the monitor.
Aug 26, 2014 | Televison & Video
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
Apr 03, 2014 | Mitsubishi WD-60735 Projection Television
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
