Wfw8300sw01 - makes loud noise sounds during spin
Wfw8300sw01 - makes loud noise during spin cycle like drum is loose or something metal is inside the drum but there is not anything in it.
  • Washing Mach... Master
  • 909 Answers
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Posted on Sep 20, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise when spinning
the bearings are going bad must be replace.
or if ou are lucky check if there is any thing inside the drum , like asmall piece of metal,,,,,
Apr 04, 2010 | Indesit W 123 Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
774 people viewed this question
Top Washing Machines Experts
