Question about Panasonic SC-PTX7 Home Theater System With 80 Gigabyte HArd Drive Theater System
The gracenote software is dated and I was wondering if there was a way to upgrade the software.
How can i add some new music
Typically you insert a music CD disk and the unit will rip the disk into its music directory. This procedure uses Gracenote to populate the MySQL database with information about the album and each song. My current experiance is that the Gracenote interface code in the SMS3 is no longer suported by the current Gracenote network portal so the SMS database is not properly populated.
Unfortunetly the MySQL database schema is not simple to modify, having several tables and associated indicies. Try to connect from your browser to the IP address of the SMS3. You may have options there to add music to the import folder which will populate the music database sans the Gracenote info.
With no support from Russound to go further you will need to change the root password to one your own by attaching the SMS3 hard drive to a Linux computer. While you are doing that I suggest you (dd) a copy of the SMS disk for later use in case of disk failure. You can use this copy later to mank a duplicate disk for the SMS3. This is not trival and you will need help from a Linux or Unix System 5 tech to really do much on the server side. That said it is just a Red Hat Linux distro with some really great script software running the media server. Russound did custom the boot ROM on the VIA MOBO but that was just to get the splash screen and a video trick to work (just guessing about the video).
Jun 08, 2014 | Russound SMS3 Digital Media Streamer
Naming tracks on my new MP3 player
The software that comes with your player uses an online database from "Gracenote" (link below)to name the tracks. When you copy from a CD the software recognises the disk & looks up the database to find the track info, if you are not connected to the internet or your firewall software is blocking the request it will not be able to retrieve the track info & will just name the tracks "track 1" etc. You can rename the track yourself in the program by highlighting the track in the PC software and pressing the right mouse button & choose "property" this opens a window where you can edit the track title but not the file name. You can update the tracks you already have by connecting to the internet then highlight & right click as before but now choose "get track info", the software will connect & retrieve the track info and ask if you want to change it. There is a problem with language CD's as they will often not be in the database and you will need to name them yourself. There are many helpful programs available (some free) to rename the tracks (technically known as ID3 tags). Search on the web for "mp3 tag software". http://www.gracenote.com/music/
Aug 09, 2007 | Samsung YPK5JQB MP3 Player
I have a problem with sync with itunes, anything i want to transfer or install apps ...it just get stuck on sync...even after it finishes ,,,nothing:((((
im not sure what you are referring to but it sounds like you might need some software
http://www.download.com/isynctunes/3000-2141_4-10452590.html?tag=api
iSyncTunes is used to transfer songs from an iTunes library on one computer to another one or from your iPod
hope this helps
Jul 14, 2012 | Computers & Internet
Ok - same itunes error 4280 - but not using a Sony CD and the drive will burn an MP4 dvd - just not CD-r or -rw discs Microsoft Windows Vista Home Premium Edition Service Pack 2 (Build...
Search Results Occurring during an attempt to burn a cd in iTunes, the Burn Error 4280 pop up in a message and is most often a result of the wrong speed of burning in the iTunes program, an issue with the cd drive, or incompatibility between your computer and the cd burner.Sep 9, 2011
Solve Burn Error 4280 with Simple Steps - ErrorAnswers.com
erroranswers.com/pc-performance/solve-burn-error-4280-with-simple-steps/
itunes error 4280 Google Search
Mar 14, 2017 | Samsung SH-S182 DVD±RW Dual Layer Burner
I get operation failed everytime I try to update gracenote
HI, check the version of your update. You might be using the wrong updating software to update or the update was interrupted.
Make sure that you are using the right software update.
Take care.
Jun 11, 2010 | Philips WACS700 Shelf System
Whenevr i put in a cd it takes forever for the
Gracenote corrupt? Try re-installing the software.
May 05, 2010 | Numark CDX Turntable
Where can I download gracenotes software for free for my numark ttUSB?
just do a Google or Bing search for gracenotes software download
Sep 10, 2009 | Numark ttUSB Turntable
Upgrading Jensen NAV101
Please go to www.horizonnav.com and then E-shop
look up Jensen and buy a new maps and software upgrade.
Mar 15, 2009 | Audiovox NAV101 Car GPS Receiver
Downloading a new cd onto Gracenote
First, you have to download a cd player software of some sort, i.e. itunes, wmp, or realplayer.  Once it is downloaded on to the player, you can sync your iriver with the player and you will have fun music to listen to on your mp3 player:)
Feb 14, 2008 | iRiver T10 MP3 Player
Vision M gracenote language problem with Vista, and software problem
ur prob may be tha it is ur windows that u are usein now i have bin told tha windows vitsa is not the best comp opp system to be useing
Dec 19, 2007 | Creative Labs ZEN Vision:M Digital Media...
Panasonic SC-PTX7 Home Theater System With 80 Gigabyte HArd Drive Theater System Logo
112 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
