Question about LG Electronics Premalite Vacuum Bagless Cyclonic Vacuum
Vacuum cuts out.
I think it may be overheating so have cleaned all filters and it went on for a little while but has cut out again. can i solve this problem myself?
  • LG Master
  • 909 Answers
You wont believe it, but that problem is very common and it is only the LG vacume cleaner that im seeing with this problem . Cant offer any solution like relocating Temp. Th/stat on motor to another position as this is non standard. (do not bridge out as motor does get warm).
Posted on Sep 20, 2009
Powerhead on vacuum shuts off after about 5-10 seconds of use. What is cause?
There are several possibilities, some of which you seem to have already checked.
1) The filters are clogged. System will cut out quickly if there is little or no airflow, to prevent overheating.
2) There is a clog somewhere besides the filter. Run through the checking for clogs steps in the manual, page 6. (
https://www.dyson.com/parts/u/user-guide/medialibrary/9118C278B029492DA662A45A70F187B0.ashx )
3) There is a small, Hall-Effect sensor near the filter that detects that the filter is in place and seated properly. If it is faulty, or the filter ISN'T seated properly, it cuts the power. Replacing that is beyond the scope of what I can safely advise on.
4) There are temperature sensors for the unit. If it's too cold, or too hot, no power. Too hot means the system thinks the battery is overheating, which can be dangerous. If the temp sensor is bad, that could do it too. This is also past what I can really help you on.
Good Luck!
Apr 20, 2015 | Dyson DC21 Motorized Power Floor Tool
How can I get my DC26 working?!
They can cut out due to overheating. Although you say you have 'cleared' the filters, they should ideally be washed as they can clog with very fine dust and cause overheating due to lack of air flow. Once a machine cuts out due to overheating it can take maybe half an hour (or longer) to cool down enough to work again.
Aug 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
No power. The motor does not turn on
Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on 'Get Expert Help' then 'Using my Dyson product' then 'User Guide'.
If this does not solve the issue you may have a bad switch or motor.
Aug 20, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My DCO7 keeps cutting out, all filters are clean, it was my mother ln laws she gave it to me, I thought I could solve the problem, there is no suction from the hose, I am now frustrated. Regards steven...
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Sep 30, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum will run for 5 minutes and shut off,
Your Dyson is designed to cut out if it becomes overheated, and it then takes about half an hour to cool down properly. If you don't resolve the problem, it will soon cutout again. Clogeed filters or other blockages are the usual cause of cutting out, but there are others, for example, incorrectly fitting valves, or broken belt. You need to do more cleaning. Follow the step by step instructions for your model, which can be found here.
http://www.dyson.co.uk/support/help.asp?article=51&product=DC07-ANIMAL
You will be following a path for solving cutting out when you are using the machine, and I would be surprised if you can't fix yours.
Jul 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vax hoover performance 2200 keeps overheating and cutting out after only 10 minutes
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Jul 04, 2010 | VAX Appliances 2000 Canister Vacuum
Dyson working one moment then it completely cuts out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Most Dyson cleaners have a thermal cut-out to protect the motor from overheating in the event of a restriction to the airflow. So, if anything causes it to overheat, it will switch off. If this happens, leave the cleaner switched off for at least two hours, as it will not start again until it has cooled down.
The most common cause of a cut-out is that the cleaner has a blockage or the filter needs washing. A high room temperature may also trigger it. Before you continue vacuuming, ensure the filter is clean and there are no blockages. You can download the user guide at www.dyson.co.uk/support/. Just click on ‘Get Expert Help’ then ‘Using my Dyson product’ then ‘User Guide’.
Dec 24, 2009 | Dyson DC07 All Floors Bagless Upright...
Dc07 cuts out
Hi!  This is the sign of a machine that is overheating, and almost certainly is caused by a partial blockage.  You need to check all the pipework and make sure the washable filter is clean (if you wash the filter, use only clean cold water, no detergent, and let it dry in a warm place for at least 12 hours, do not force-dry). I hope this helps.  I value your feedback, so please remember to rate this response. Good luck!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
LG Electronics Premalite Vacuum Bagless Cyclonic Vacuum Logo
561 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Tim Venetis
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
