Question about Panasonic KX-T7730 Corded Phone
Lights not able to go off .There is an indicator light on the top right of the phone.Its on all the time. Pressed 1 it goes off but comes on again after a while.
  • Panasonic Master
  • 2,460 Answers
The light on the absolute upper right that flashes on incoming ringing and shows MESSAGE WAITING, can go out if you clear all messages.
From the intercom, try dialing 700 plus your extension and maybe # to clear all messages.
Carl
Posted on Sep 23, 2009
How do you know if you have a voice mail message
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
May 28, 2014 | AT&T GoPhone Radiant
The heater light light comes on when first low circulation cycle is pressed but turn off when you press again but only for 20 minutes
It is supposed to. When the heater reaches the temperature you set, it goes off and the indicator light goes off too telling you the heater is off. Soon the temperature drops again and the heater, and the indicator light, comes back on.----This is the working procedure.------ The pressure switch, float switch all needs to be inspected.------- Also what is the exact brand and model of your heater.This will help, to get exact cause of the problem. --------- Keep updated, thanks.Helpmech.
Aug 13, 2011 | Pool & Spa
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
F2 code
Hi, F2 code on the Kenmore indicates a problem with either of the control board and the user interface board. Run the console and indicators diagnostic test mode to find out.
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press START within five seconds when "dt" shows on the display. All indicators in display are lit and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the functions. The indicators switch on and off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the control board, the user interface board, and the connection between them.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector and the terminals thoroughly with brush and alcohol.
  • Reconnect and disconnect the connector several times.
  • Reinstall the console and reconnect power.
  • If the problem is not resolved, replace the user interface board.
  • If the problem is still not resolved with the replacement of the user interface board, replace the control board. You may also replace both board at the same time and keep the old good board as a spare.
Take care
Jun 20, 2010 | Kenmore Oasis 27042 Top Load Washer
Starter will not engage anti theft light is on it is a 2005 cobalt
I found this on a website try this
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
(RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
4. When the light goes off the third time, the new key is programmed into the computer and will start
the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
an existing key to start the car.
Mar 25, 2009 | 2007 Chevrolet Cobalt Coupe
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
Light indicator when burner is turned on will not shut off.
if there is one light for all the switches, you will need to unplug the unit, take off the top part of the back panel to get access to your switches. the indicator light is run to all 4 switches. you will need to unplug the wire that goes to the indicator light from each switch ( only one at a time ) and plug the unit back in each time. do this for every switch until the light goes out. whichever switch has the indicator light wire removed from it when the light goes out is the switch that needs to be replaced. if your unit has an indicator light for each switch, then just replace the switch that is above the indicator light. Joe
Dec 12, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
WHY WONT MY 7280 CHARGE OR TURN ON
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Jun 04, 2008 | RIM BlackBerry 7280 Handheld
Control panel lights
The manual indicates this means that it is time to decalcify the machine.  After doing so, press the ON/OFF and PROG buttons at the same time for 2 seconds.   Jeff, Burbank CA
Dec 11, 2006 | DeLonghi CAFE DUO Dual Drip Coffee Maker
Panasonic KX-T7730 Corded Phone Logo
160 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
