Question about Cuisinart DCC-1200 Coffee Maker
It's telling me to self clean?? Can't find manual
  • 8,596 Answers
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Posted on Sep 29, 2009
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
How o clean my roper self cleaning oven
i wouldn't use the self clean,more problems than good,the oven gets up to 1000 degrees and can damage electronics in oven,you need the model number off of the oven,you can google it and find manual to tell you how to put it into self clean but like i say you're better off doing it with easyoff,also don't use self clean near holidays or any other speacial occaisions,in case it does do damage,you might not be able to get parts or parts will have to be ordered and might take longer than 7 to 10 days depending on brand name and age.good luck
Oct 19, 2014 | Ovens
Pictures have lines on them and the picture is blurred
Most likey cause of this is dirty print heads. The print head is the part of the catridge that the ink comes out of.
You should be able to get the software (HP toolbox) to tell the printer to do a self-clean...otherwise you can try a manual clean below
Remove the cartridge and inspect head. If clogged with ink then you can manually clean them with a wet cloth (lint free cloth). just use water ...no cleaning solution...as ink is water based.
I would recommend re-doing the self-clean after manual clean also.
hope this helps
Sep 02, 2011 | HP PSC 1210 All-In-One InkJet Printer
I DON'T HAVE MY MANUAL, BUT NEED TO USE THE "CLEANING" OPTION TO CLEAN BURNT ON FOOD. CAN YOU TELL ME HOW TO DO IT?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 11, 2011 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
I do not have a manual to tell me how to use my self cleaning oven.
heatman101
Dec 24, 2010 | Microwave Ovens
I want to use the self cleaning feature but have lost the manual can you tell me the procedure to follow would it be possibel to obtain an instruction manual thank you
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.maytag.com/support/manuals_literature.jsp
Enter your model number CWE5800A
It will ask you what kind of visitor you are... enter that in the drop down menu (Consumer)
There ae 9 manuals for this unit... the alpha letters after 5800 of your model number are what will determine which manual you down load.
The first manual for model CWE5800ACB is here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10169639.pdf
Self clean steps are on page 9 of the manual. Make sure you read the steps "Before Self-Cleaning" It will tell you to remove the racks and some other important steps.
Thanks for choosing FixYa,
Kelly
Dec 10, 2010 | Maytag CWE5800A Electric Double Oven
Need the manual relative to use of self-cleaning mode for Whirlpool Electric Oven Model RJE365B
You can get the manual on the link below. Bottom of page 9 wil tell you how to self clean.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20310615.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
No User's Manual
I have a Crosley csf395001 and no manual, how do I turn on self clean option
Mar 26, 2010 | Crosley Kitchen Ranges
Self Cleaning feature
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir
to capacity with a mixture of 1/3 white vinegar
and 2/3 water. Press the Self Clean button.
When the self clean light glows, turn the
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
The coffeemaker is now in Self Clean mode.
One cycle should be sufficient to adequately
clean the coffeemaker. When the cycle is
completed and the five beeps sound, the coffeemaker
will shut off. Turn the coffeemaker
ON to see if the Self Clean light continues to
flash. If it does, turn it to OFF and then repeat
the cleaning procedure with a fresh solution of
vinegar and water.
If the Self Clean light no longer flashes, turn
the coffeemaker to OFF and then run one
cycle of fresh cold water through the unit
before using the unit again to brew coffee.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
Feb 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
1,011 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
