Question about Digipower Travel Charger for Select Olympus Batteries
Digital olympus charger not charging battery
I have a Digi power, BP-OL40 battery and trying to charge it on the olympus travel charger using the correct plate and the let never changes off steady green, I do know the battery is dead.
4 Suggested Answers
Agent Allan
  • 480 Answers
SOURCE: Battery charger for Olympus E-500 camera
dear cienkusmike,
This charger should work to charge the battery that came with the olympus E-500.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Posted on Apr 17, 2008
  • 178 Answers
SOURCE: my digipower travel charger flashs red when the
For mulitply camera battery charger ,there are many special online shop for you to select on the internet.
Posted on Aug 13, 2010
  • 479 Answers
SOURCE: I have olympus camera battery
three things to try.. reverse polarity on the charger (turn the plug around), clean the copper contacts on the battery and charger, get a new battery
Posted on Jun 29, 2011
No connection when trying to charge battery
hello there!
i will help with your problem. just follow these steps.
1. remove the battery and memcard. 2. put it back and make sure that it properly put.3. connect the cable of the charger and charge it.4. make sure that the charger is properly plug in in the socket and in your digi cam.5. if still not charging, try to charge to other power outlet.
if still not working, call a service center or an authorized repair shop and ask them to check your digi cam. there must be a problem inside.
thank you for choosing fixya and kindly rate my post.
Jan 25, 2012 | Olympus STYLUS TOUGH 8010 Digital Camera
My cammera will not charge! The orange light does not show up when charging ???
There are 3 possibilities to charge the battery of the camera:
1. Connecting the Olympus' USB cable to camera and computer.
2. Connecting the wall charger to the camera with Olympus' USB cable.
3. Using a specific separate wall charger for LI-50B batteries.
Be sure to connect the cable well and if the orange LED does not light when trying to charge the battery using above points 1 and 2, there might want to exchange the Olympus' USB cable first to check what's wrong. (Cable model: CB-USB6). Another point is to check if the battery is seated well in the camera.
Jun 05, 2011 | Olympus SP800UZ Digital Camera
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
How to start since the power button does not react? How to charge battery?
Try recharging the battery. If that doesn't work, try a new battery.
Use the supplied charger to charge the battery. If you've lost the charger, you can get an LI-41C charger from Olympus. You can also get LI-40B or LI-42B batteries from them.
Jan 15, 2010 | Olympus FE-340 Digital Camera
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Jun 14, 2008 | Cameras
dear cienkusmike,
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 08, 2008 | Olympus EVOLT E-500 Digital Camera
Camera does not turn on.
I had a similar problem and it was a result of the battery not charging correctly. I bought the travel battery charger and an additional battery from amazon to see if maybe the battery was just old or just not charging. I figured out that the internal camera charging mechanism just wasn't working b/c the battery charged fine with the travel charger. I like the travel charger better and with two batteries I can charge one while the other is in use. I haven't had a problem since. When you buy the new battery you still have to charge it before it's first use. I hope this works for you as it did for me.
Jan 06, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
Digipower Travel Charger for Select Olympus Batteries Logo
99 people viewed this question
Top Digipower Cameras Experts
Saleem Baig
Saleem Baig
Arthur Cowgill
Level 1 Expert
Are you a Digipower Camera Expert? Answer questions, earn points and help others
