Question about Garden
Husqvarna YTH2348 stalls after 20mins
Two issues, possibly related.
Less than 100 hours on motor
1. Have to keep charging battery. Had it checked at a local auto parts store, checked OK. Suspect bad charging system. I have not put a meter to it ...yet.
2. Unit runs apprx. 20-30 minutes just fine then suddenly acts as if it's starving for fuel and stalls. Usually starts right back up with full choke, but stalls once transmission is engaged. Battery usually too weak to restart more than twice (30 minutes after recieving a full charge). Replaced fuel filter, inspected gas cap, appears OK. Suspect I may have to replace the spark plug and clean the carb. AND address the charging system
Can these 2 issues be related or am I not even in the ball park? Your opinions welcomed. Thanks!
  • traboH Mr
    traboH Mr Sep 20, 2009
    Thank you Mowerman for the quick response. Yes you are correct Briggs 23hp
    Fully charged the battery 12vdc. Cranked right up 13.5-14vdc at battery on full throttle... a good sign!
    Engaged the electric blade clutch engine bogged down and stalled without any load on the blades. Battery voltage down to 11.7vdc. Will not turn starter. 4.5 vdc when trying to start. New battery in order despite what the auto parts store said, yes?
  • 389 Answers
First thing to do is check and repair charging system. They are/could be related problems in that there is an electric fuel shut off solenoid on the carburetor and if the battery is going dead, it could be cutting off the fuel flow. I wouldn't worry about the spark plug or cleaning the carburetor just yet.
Put a meter on the battery terminals, run the engine at full speed and check the voltage, If you are not getting around 13,5 volts going back to the battery, repair/replace the charging system. If it is less than 2 years old, it should still be under warranty so you might want to check with your dealer. I am guessing that it is a B&S 23 HP and replacing the alternator can be expensive and time consuming
Posted on Sep 20, 2009
  • traboH Mr
    traboH Mr Oct 22, 2013
    No Ethanol gas soved this problem outright
My YTH2348 mower won't turn over power comes on but that's it!
1. Check battery connections are clean and tight
2. Check the battery is FULLY charged, test with a car battery and jump leads to see if engine will start OK.
3. If it still won't start then you will need to check the starter solenoid with a voltmeter - this will also tell you if the ignition switch is working OK.
4. Still no luck? Then you need to check the starter motor.
Aug 03, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 just quits while mowing...
check the coil on it,not a fuel problem if the coil gets hot it will shut down and when cool cranks back up,my dad is a lawnmower mechanic!!!
May 14, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What's your problem?i got a problem with the battery of my zte warp..how can i keep it charged at less one day?..it takes 2 hour to stay uncharged
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 09, 2012 | ZTE Warp
My hp pavilion dv4 laptop's battery cannot sustain even for 1 hour.please give some ideas to maintain the battery and is there any remedy for this issue.Also which is better among, using laptop always...
If the battery appears to be charging, the drop in the time it sustains power is likely due to a faulty or old battery. Eventually it will appear 100% charged and drop to zero in 5 minutes or less. I would think you need to replace the battery.
If you want to maintain the battery properly, it is best to remove it once fully charged and use on ac power alone. If using the laptop on battery, remove the AC connection and allow the battery to fully discharge before recharging it ( there is some debate on this method, other may disagree)
Jul 14, 2011 | Computers & Internet
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 engine stall issue 23hp B&S. Full charge on the battery 12.7vdc. New fuel filter. 13.5 - 14vdc at full throttle. Cranked right up cut grass 20 minutes +/- begins to sputter as if...
Mine was doing the same thing. Just loosen the gas cap. If its on too tight the engine will stall because the air cant get into the fuel cell to replace the abscent fuel.
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
210 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
