New MFC8480DN -- after initial setup, I pressed fax and copy buttons per instructions to print sample page. Pages keep jamming. Finally, after clearing jam numerous times per instructions, I tried to print a sample page and heard a grinding noise. a piece of paper appears wound around inside the cylindrical part of the drum/toner cartridge.
  • 186 Answers
SOURCE: print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Posted on Jul 08, 2007
Corysf62
  • 188 Answers
SOURCE: paper jam without any paper deskjet F370 all in one
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Cory
Posted on Nov 06, 2008
  • 9 Answers
SOURCE: HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
Posted on Sep 16, 2009
  • 121 Answers
SOURCE: Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Posted on Oct 08, 2009
FixinFax
  • 3085 Answers
SOURCE: After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Posted on Nov 20, 2009
How do I reset my MFC8480DN after I have replaced the laser unit?
With the unit turned on and in ready state, press #'s 3 and 9 together and hold them down untill display changes to reset menu. Then scroll down to drum reset and follow prompts on display.
Feb 10, 2015 | Brother MFC-8480DN MFC8480DN...
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Mar 07, 2011 | Brother IntelliFax-2820 Laser Fax
Can you print a configuration page on this device. I need the meter reads/volumes.
Hi, you can print a configuration page from the C6180 by following these steps:
- Press the Setup button on the printer's operation panel
- Using the down arrow button, scroll down until you see Network, then press OK.
- Scroll down again until you see View Network Settings, then press OK.
- Scroll down until you see Print Network Configuration Page, then press OK.
To view configuration page instructions and ways to view page counts on other printers, copiers, and fax machines, visit the How to Print Configuration Pages blog.
Feb 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have a Brother MFC-210. It was working well. When I moved and hooked it back up. It was printing some pages fine and then it started printing double like 3d. Started with a few words. Now the whole page...
Check the alignment. Press the key for Ink or Ink Management on the Control Panel. Select Test Print (the up/down arrows) and hit Menu/Set or Set. Select Alignment and press Menu/Set or Set. Next hit Mono (Black) Start. Look at the Alignment Sheet that prints out. Press 1 if the number 5 sample matches line 0 for both 600 and 1200 DPI samples. Press 2 and then the number for the line that matches that matches the 0 sample.
Then press Stop/Exit. Repeat this for color printing by using the Color button.
You should also check the Print Quality. (Very similar menu choices - just choose Print Quality after choosing Test Print but you only need to hit the Color button to print the test sheet.) This will initiate a cleaning cycle for any poor quality ink test pattern. You will need to respond Yes or No for the print quality and each ink (if you answered No). If you do the cleaning 5 times with problems, replace the cartridges in question.
Finally try cleaning the printhead (Press Ink or Ink Management and then 1 for cleaning) If 5 repeats do not help, contact Brother support, the print head may need to be replaced. (Unfortunately, this isn't the only reason for the problem. Once you put in a print head, it isn't returnable. It could be that the entire printer is ready for recycling.)
I hope this helps.
Jun 24, 2010 | Brother HL-2040 Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
7310 faxing problems
Try to reset the printer.
Take out the power cable without turning it off and then press # and 6 and while pressing # and 6 plug the power cabel and keep pressing the buttons.
The unit will turn on and then turn off...release the buttons and then press the pwer button and turn it on.
Try to fax now.
Also open the adf cover and clean the roller and seperator pad.
Apr 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Won't print faxes that are in memory...
what type of fax machine is this ? model serial #
Mar 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
170 people viewed this question
k24674
jasbo
jasbo
