Question about Siemens SpeedStream 6300 (33A6300001) Wireless Router
Using speedsteam 6300 wireless router with another ISP
Can the speedsteam 6300 wireless router from bell be configured for use with another ISP?..If so how would this be done?
Thanks
Forgot password
The system's default password is located on the back of the unit. A series of numbers and or letters in brackets. If you have changed the default password, you will have to reset the router back to factory by pressing the reset button on the back for up to 1 minute. Once this is done, you will lose your Internet Access until the unit can be configured through the wizard provided by your ISP. You will need to call your ISP and provide your credentials in order to have them assist you (free). The basic routine is to configure your ISP provided email address and password to connect via PPOE. Once that is done, you should be back online and able to configure any other settings you may need for firewall settings, manual IP addresses etc. If you need more information, feel free to contact me. I use this same exact unit with my IT business. I have to reset it occasionally as these are not very stable, especially on the wireless side. I am also on my 3rd one for bad power supplies in the last year.
Sep 08, 2010 | 2wire (2701HG-B) Wireless Router
Tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Jul 09, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Connection problem
you need to connect the wirless router directly to the internet line and configure it. note that some isp do not support such devices being used as a modem. after connecting the main line to the router open a browser and enter 192.168.1.1 as the address. enter admin as the username and the password. if it does not work ask your isp for the unsername and password.
configuration will have to be done including assinging and ip address to the router. A technician for your isp (internet service provider) should be able to help you in the configuration or a technician.........will love to but i do not reside in your country and do not know much about your place. with all that said Remember that without the configuration process it will not connect as you said.
Let me know of the outcome.
good luck
Jul 04, 2010 | Linksys Wireless-G Broadband Router
I configured the belkin router Belkin wireless-n
if the router is still under warranty or you have an existing ISP,you can try to contact them since they are the only one who knows how to configure that,theres a possiblity that they will reset everything
Jun 28, 2010 | Computers & Internet
As soon as i plug in my d link wireless router into my laptop i loose my internet conection why is this
The router should be configured manually if it didn't work atuomatically. If you are on DSL ISP, configure the router on PPPoE connection type. If you are Cable ISP, configure the router for MAC Cloning. You can read the manual on how to do PPPoE or MAC Cloning.
Oct 23, 2009 | D-Link DIR-615 Wireless Router
If I have a wireless router do I still need a modem?
It is depend on which type of connection cable your internet service provider.
You don't need modem if in your router ADSL port and your ISP gives you ADSL but if on wi fi router there not dsl port and your ISP gives you dsl cable then you need modem.
Let me know if you need more assistanse.
Thanks.
Sep 11, 2009 | NetGear WGR614 Wireless Router
I have a used 802.11g/2.4Ghz wirless router and i dont know how to use it cause i dont have a cd or directions it was used by my cousin like 3 years ago i would like to use it please help. I have a cable...
First you have to re-configure the Router according to your Internet connection (ISP setting). Any software disk is not required to configure the Router. Just login to your Router and configure.
To login to your Router just use the IP 192.168.0.1 (type in Web Browser) to get in.
The default Username is "admin" and there may be no password or the default password may be the 'password'.
Now input the details like your ISP username, password, IP address etc. to configure the Router.
You may also refer the User Guide of the Router to configure it.
Better do a Google Image search for for information:
http://images.google.co.in/images?hl=en&um=1&sa=1&q=how+to+configure+wireless+router&btnG=Search+images&aq=f&oq=&start=0
Good Luck!!!!!!!!!!!!!!!!!!!!
Sep 05, 2009 | D-Link High Speed 2.4GHz (802.11g)...
Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Feb 22, 2009 | Actiontec GT701WG Router (actiongt701wg)
Can't configure belkin n wireless router.
yes always best to use ethernet when you can.richardm69
Feb 03, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Siemens SpeedStream 6300 (33A6300001) Wireless Router Logo
139 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
