Question about HP Deskjet F2210 InkJet Printer
Hp deskjet F2210 won't install. I unplugged the usb cord while the computer was still on and the printer wouldn't print. So uninstalled the software and reinstalled it but when I get to the point in the "install" where the software asks me to connect the printer via the usb cable, nothing happens. The software or my laptop don't recognize the printer. Help.
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
  • 13433 Answers
SOURCE: HP Photosmart C4180 won't print
hello
you can get the newest vista software for your laptop from
CLICK HERE
Posted on Apr 28, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
XeroxHelp
  • 4 Answers
SOURCE: HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Posted on Feb 17, 2009
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
I cant get my deskjet f2210 all in one printer to scan. it blinks a thousand times and then does nothing. I realized i didn't have the hp photosmart essential software so i downloaded it but it still...
Try installing the latest drivers from the website. To download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
But before Installing the Software, use the Disc that came with the printer so you can do an L3_Uninstall first.
To go for an L3_Uninstall:
1 Go to My Computer (XP), Computer (Vista and Win7) 2 Right Click on the Driver CD, The one that has the HP Logo 3 Open Util 4 Open CCC 5 Double Click on the icon that says Uninstall_L3
The Uninstall will prompt you to restart the computer once it's done. After doing so, Install the newly downloaded software.
Try scanning again, I hope this worked. :)
Feb 07, 2011 | HP Deskjet F2210 InkJet Printer
How to installl HP F2210 Printer without the Cd Disk
Drivers and full software are available from HP for supported OS versions: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3571753& . Select your OS and then click Next. From that source you can also order a replacement CD if you need it.
Download the software and install it before connecting the USB cable to the computer. If you connected the data cable first, remove the generic OS driver and then disconnect the USB cable before installing.
I hope this helps.
Dec 07, 2010 | HP Deskjet F2210 InkJet Printer
I have hp deskjetf2210 and just switched to windows 7 it is showing that it has the new operating system, and appears in queue, it just is not printing
Hi
Please go to the Control Panel > Remove Programs or similar, and remove all HP printer related software.
Then download and install the Windows 7 version of the HP software here.
Mar 03, 2010 | HP Deskjet F2210 InkJet Printer
How do you connect the hp deskjet f2210 inkjet to your computer?
If you're going through the install process, please don't connect the USB cable until told to do so by the installation software.
Look on the back of your computer for USB port. It look like this...
If you need to see the setup documentation, follow this link...
http://h10032.www1.hp.com/ctg/Manual/c00901207.pdf
If you need the user manual, follow this link...
http://h10032.www1.hp.com/ctg/Manual/c00901355.pdf
Oct 26, 2009 | HP Deskjet F2210 InkJet Printer
I have the cords but i dont have the cd waht do i do?
You Need to install the full feature software for the printer ;
First uninstall the entire software from your computer
Unplug the USB cable;
Click on "Start" >>> Control panel >>> Add or Remove program >>> Select the HP printers software >>> CLick on remove to uninstall the printer software;
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
This should resolve your Issue
Regards Soumajit
Oct 01, 2009 | HP Deskjet D1455 InkJet Printer
HP Deskjet F2210 Will Not Scan
1. Installed software ?
2. On the software when you click SCAN
does it make any noise? or movement?
3. If the software is installed correctly then you might have to:
a. reboot the computer
b. turn off the printer / reset
c. see if this works
Sep 07, 2009 | HP Deskjet F2210 InkJet Printer
HP Deskjet F2210 won't install on Vista
Go to control panel/programs and features and uninstall the HP driver and all associated software.
Reboot, then reinstall the LATEST version written SPECIFICALLY for VISTA SP2. Install the driver BEFORE you connect the printer. After you install the driver if your computer still doesn't recognize the printer, leave it connected and reboot.
You should see the 'found new hardware' wizard open and automatically install the printer.
Hope this works. Good luck.
Jun 11, 2009 | HP Deskjet F2210 InkJet Printer
Can not print anything off the internet
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | HP Deskjet F2210 InkJet Printer
I want to know if my All in one HP Deskjet F2210 All-in-One Print
What Operating system are you using?
Windows XP: Go to Control Panel > Add/Remove Programs
Windows Vista: Go to Control Panel > Programs and Features
Check if you have the OCR Software listed in there
If it is in the list:
  • uninstall it
  • run the installation CD for the printer
  • click on Install more software (or just do the recommended/easy installation)
If there is no OCR software showing in the list:
  • run the installation from the CD to install it
In summary, just make sure that the OCR software is either refreshed or reinstalled.
Jan 12, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP Deskjet F2210 InkJet Printer Logo
172 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
