Question about Canon PIXMA MP780 All-In-One InkJet Printer
Lines going through picture - Canon PIXMA MP780 All-In-One InkJet Printer
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
Blank screen audio ok. Picture tube has a line only going up and down
adjust voltage G2 Screen. thats why have retrace line. resolder also CRT board.
May 31, 2009 | Proscan PS50700 50" Rear Projection...
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
LCD TV picture has vertical lines through picture equal spacing
Call 323-767-6030 and I will go through with you.
Dec 09, 2008 | Televison & Video
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
No picture
these systems usually go alomg with a power supply going bad the last one i did tthe 24 v converter for the picture went out.
Aug 14, 2007 | Polaroid FLM-3734B 37 in. LCD HDTV
Line going thru the tv
Josh, When you say a line going through your TV is it a line from left to right or top to bottom? Is there a picture present and this is a line imposed on the picture or just a line by itself? Let me guess, you have no picture just a horizontal line (from left to right) across the middle of the screen. If so that is collapse of the vertical deflection and most likely caused by failure of the vertical IC and possibly linked to some bad caps in theat circuit as well. It's not an expensive repair, just find a good reputable shop. You might also mention, or if they ask, that your unit is a lighbox. Meaning that when they go to repair it the insides of the unit separate from the cabinet for easier access.. Good Luck Bill
Jun 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
My printer makes lines through all the pictures i try to print
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
