Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
I have a Bosch SHU9915UC/U11 dishwasher, installed in 2002. Recently, our hot water heater had to be replaced, and we were without hot water for five days. Air got into the hot water pipes, and dried out all the debri in the lines. When we got the new hot water heater going, all of the sediment in the pipes ended up in the in-line screen filters in various appliances (clothes washer, etc.). I have cleaned these out, and these appliances are fine. Since then, the dishwasher has been shutting itself off about 2 minutes into the cycle, apparently for lack of water flow. I've taken off the kick panel and know where the water inlet line goes (having installed the unit myself). I'm wondering where I might find some kind of in-line screen-type filter that is presumably clogged with debri. Can you help me with this?
  • 2 more comments
  • Harrison1962 Sep 20, 2009
    OK, let me try this, and I'll get back to you.
    I have taken the inlet water line off, and am trying to get the valve out. It won't just pull out (electrical connections?). Is there any easy way to get the door off to dramatically improve access? How do I get the valve out? Thanks. I have an i-Phone photo of this if you like.
    Have you had a chance to answer my question? How can I get the valve out and is there a way to get the door off?
    Thanks.
    So far, so good, but I'm waiting to hear back from Tom.
  • 220 Answers
All inlet valves have a screen built into the valve itself,shut off the water remove the entire valve and you will be able to see built in screen,if you flush out the debris from it and re-install the valve it should work fine.
Posted on Sep 20, 2009
My SHU9915UC was probably installed by the previous owner in 2002. It is not working properly, may be the impeller or pump is jammed. Is it worth spending a few hundred dollars to fix it or spend another...
This model new was around $1000 dollars. I would put a few bucks into to get it back up and running. The most common issue is the circulation pump. The pump freezes up and will often cause this issue.
Appliance & Refrigerator Repair
Mar 22, 2011 | Bosch SHU9915UC Dishwasher
I have a Bosch dishwasher, model SHU9915UC/U11. The spring mechanism on the detergent door cracked, and I bought the part to replace it. I took the front cover off of the dishwasher to determine how to...
Hello! This is Guru...Saailer...I have your information...Due to size limitations I'll need your e-mail address in order to send it to you...Send an e-mail to me and I'll send an exploded view diagram and parts list...Guru...saailer...
Saailer@ec.rr.com
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 23, 2011 | Bosch SHU9915UC Dishwasher
Wash doesn't go through its full cycle, then will not drain. or cycle keeps on going
Hello, Welcome to FixYa. **What I`m about to share applies to All B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.** Based on your description I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher. That is just a suggestion out of courtesy however... If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to. The reason your dishwasher never completes a cycle is the control has detected a heating error. Here`s the most likely reason why it has detected the error... Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry. The issue with your dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless you "stop" it or by pressing the two buttons for "cancel". To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied. Good luck. macmarkus :)
Oct 25, 2010 | Bosch SHU9915UC Dishwasher
No water going into never used bosch shu9915 dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 27, 2010 | Bosch SHU9915UC Dishwasher
Leaking water.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
nnb
Jun 05, 2010 | Bosch SHU9915UC Dishwasher
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Jul 31, 2009 | Bosch SHU9915UC Dishwasher
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
