Electrolux Centralux Vacuum
Problem for Electrolux Centralux Vacuum
My vacuum hose has split very close to the handle-
By l_ferrazzo on Sep 20, 2009
my vacuum hose has split very close to the handle- how do I remove the handle, cut the hose at the split & reattach it to the handle unit - Centralux central vacuum system. Where can I find a diagram of how to remove the handle?
Best Solution
posted on Sep 20, 2009
Very Helpful)
Chemist1961
Rank: Guru  Electrolux Vacuums  Expert
Rating: 93%, 131 votes
Do Not Cut the hose!
It has wiring inside to control the vac and power head. This is a swivel handled hose with both low and high voltage contacts in it. The same wiring which gives the hose its ribbing, is conducting current for two applications,
If your hose has a switched handle, a very experienced, trained AERUS Electrolux tech will a have a tough time doing this job and will likely refuse as it is not recommended per company policy.
You can purchase a shrink wrap tube which will prolong the life of the hose if it has not collapsed, however this is a short term fix.
I could walk you through this as I have done it before ...Unfortunately, even if you were able to dismantle the hose successfully you would not be able to purchase the wire terminals which you would cut off the end when shortening . Sorry its a proprietary part.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thanks for your advice. Looks like I will have to purchase another hose. " - l_ferrazzo
Popular Solutions for Electrolux Centralux Vacuum
Questions and Unsolved Problems for Electrolux Centralux Vacuum
Do you recommend Electrolux Centralux Vacuum?
Answer
Answer
I just bought a Z1750 twin tech vacuum. I am wondering if I can buy a power brush attachment for... (More)
Answer
Hi I need help with a problem I am having with my Frigidaire Gallery Stainless Steel Dishwasher... (More)
Answer
I want to remove the hose from the handle of the vacuum? I already removed the plastic clip. I... (More)
Answer
How can I clean the filter in the canister of my condolux system? Is it removable?
Answer
The 'self clean filter' icon flashes. Really annoying, what am I doing wrong? It is a electrolux... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux Centralux Vacuum:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
