This is a setting that you cannot change from your handset. You will need to call your wireless provider and they can lengthen the ring time before your calls are routed to the voicemail system.
check your ignition key,,,it may be the alarm cutting the motor off if you have another key near the main one,,,my honda is just like this one is? only keep the bike keys on the key ring,
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
hello you need to go into your settings then click on divert, it will say your settings are on divert:if unavailable thats why your phone call cuts off if you havent answerd it in a certain amount of time. So just turn divert off completely and your fone will ring longer
depends on your carrier. Most carriers have their own ringtones you can buy. I perfer the free stuff though. If you have access to outside wap sites other than those provided by your carrier check out myxertones.com. It lets you cut your music and download other peoples cuts. There are also cool walpapers and most everything is FREE!
suggest have you tried the EEPROM phone reset code *2767*3855# then use *#638738# to choose your regeion/country this should put the phone back to original factory settings. You never know unless you try.
Good luck.
*****back up********
