Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Frost on icemaker where it comes out.
This is the only place where frost accumulates - please help.
The ice chute door is not sealing properly. The door hinge is likely broken.
Posted on Sep 21, 2009
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Pipe behind freezer look red hot
Hi, yes you bet they do, at least modern day "frost free" firdges do. As the saying goes though, "out of site out of mind". Not to worry, this is the way the fridge keeps from frost/ice building up on the evaporator. It defrost's by way of a heater which does heat to a point to melt the frost, be it only briefly though ( usually 10-20 min. depending on the frost accumulated and the bi-metal thermostat tolerance...the part which insures it shut's off ). Anyway, I hope that re-assure's you this is normal and perfectly fine. If you however, think you want a pro to come and look at it, than that is what you should do. Hope this has addressed your concern or inquiry. Thanks for visiting "fixya" for assitance today, please take a moment to rate the info provided to you, whether helpful etc. Thanks again. Macmarkus :)
Mar 02, 2010 | Refrigerators
The opening were the ice comes out has frost cyrstals.
if the ice is coming out then this shouldnt be a problem, warm air from the kitchen is condensating when the icemaker is activated,
Oct 03, 2009 | Amana ARSE66MB Side by Side Refrigerator
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
Excessive frost buildup in bottom freezer section of Kenmore refr
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. if this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that can occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of your ice maker causing this are very, very slim...in 35 years in the industry ..I have never had an ice maker cause frost due to water spray...it will almost always result solid sheets of Ice..if it evers does cause a spray....which like I said is rare...lottery ticket type rare :-)
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Mar 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icing and frost clogs the ice dispenser
check the dispensing flapper ,, it may not be shuting there is a spring and lever it the lever is bend or if the spring is broken it will not close correctly clean and clear all the ice .. then check that it will close after you open it...hope it helps
Sep 07, 2008 | KitchenAid Superba KSCS23IN Side by Side...
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
Fujitsu general ars40 duct type
you have to clean your A/C unit, indoor and outdoor, be sure all frost are de frosted before you run your unit again, or else it will frost again. if this not work your unit need re-gassing.
Jan 20, 2008 | Fujitsu 24R1 Air Conditioner
Refridge
Sounds like the icemaker mold is leaking so the whole icemaker should be replaced.  Leaking water will get on the icemaker heater and cause condensation which then freezes and makes frost.
Oct 17, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
