Question about HP DeskJet F380 All-In-One Printer
It's stopped printing there is paper in? i keep repressing teh print button but nothing
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
The printer was printing several pages, then stopped, made a humming sound. I recieved teh error 13, and had to remove a sheet from the rear of the printer. Now when i hit the online button, there is a...
It sounds like the fuser gears are broken, that happens with paper jam sometimes from all the heat of the fuser. A new fuser will probably run around $100.00 for that machine.
Jul 14, 2009 | HP LaserJet 4p Printer
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
Printer keeps printing garbage
i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
Mar 31, 2009 | Minolta DiALTA Di183 Copier
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Mar 24, 2017 | Canon BJC 4400 InkJet Printer
Printer will not print
I have the same problem nothing will print a need to print a fax report I need a confirmation.
Sep 02, 2008 | HP Officejet 4315v All-In-One InkJet...
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
61 people viewed this question
Ben Johnson
