Question about Ryobi Tools & Hardware - Others
My almost new ryobi ert1500 router stopped working.
My ryobi ert1500 router stopped working. no burning smell. brushes are ok, switch bypassed and still won't work. can you help?
I took the switch apart, it was full of dust. Cleaned it and put it back together. Usually I would not call the router sound sweet but this time it was.
Posted on May 14, 2013
Changed the switch
Posted on Sep 21, 2009
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Whe sing router speed suddenly reduced and brushes started burning..changed brushes and bearings and problem persists.even tried bypassing switch yet it still behaves the same
Sounds to me that the brushes burned as a result of the low speed and the fault may actually be a winding's problem in the main com, insulation on the winding's may have broken down resulting in slow speed. I think this may be time to look for a new router on ebay it would probably be cheaper than getting the com rewound if at all possible.
Jun 27, 2014 | Bosch 1617EVS 2 Router
I need to repair my ryobi router
Pull the brushes out and make sure they are in good shape. Sping the motor by had then put the brushes back in and see if it works. Often times the brushes get blocked by wood dust. If not check the power cord and switch for continuity.
Apr 19, 2014 | Ryobi Drills
I have a 14.4v Ryobi cordless angle drill which inexplicably stopped working. Had charged the batteries which I believe are fine and have cleaned the contacts in the battery compartment all to no avail....
Do you have a multimeter to check the battery voltage? Also, you can check the function of the trigger, bypass it and see if the drill works.
Jul 17, 2010 | Ryobi Drills
My Ryobi router is not working at all. It spins
It can be any number of things that cause this:
1. Broken power cord
2. Failed on off switch
3. Failed trigger switch
4, Brush or brush tube assy failure (Most common failures)
5. Open armature winding
6. Open field winding
If you can not get continuity across the power cord with the switch on and trigger switch depressed yhe only option for further troubleshooting is to open the unit.
You can go to this page then click on go to power tools store and under model number use R161
http://www.ryobitools.com/support/parts_batteries
The manual lists all 50 parts in your unit.
Item 16: Brush assy part # 968304-026
Feb 04, 2010 | Ryobi ROUTER KIT P163K
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Keeps stoping (like its the trigger)
assuming the cords ok..
check the carbon brushes and the armatures commutator (also see if you smell anything burning)... if your thinking its the switch...open the handle and bypass the switch applying 115v directly to the motor wires that enter the load side of the swicth.
good luck
Jun 05, 2009 | Makita Hr4510c Avt Sds Rotary Breaker...
Ryobi cordless drill burning smell
your over using the drill on havy jobs
Apr 11, 2009 | Drills
Rf1101 makita router lost serious power and is sounding wounded
You dont have to take the armature out to look at the commutator, just remove the brushes (unplug tool first) and get a flashlight and look into the brush tube and slowly turn the shaft by hand and look for a discoloration or unusual look on the comm bars. The slight burned smell might have come from the speed control or the switch itself, but look at comm and then go from there. You can get a breakdown for this tool at Makitausa.com. Let me know if you need any more help
Feb 19, 2009 | Makita RF1101 Electric Routers, Fixed &...
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Tools & Hardware - Others Logo
420 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
