Question about Sony STR-DE485 Receiver
I have a sony str-de485 reciver im trying to get digital sound it is only playing in prologic. im trying to hook up my xbox 360 the digital option is activated on the xbox i have a fiberoptic cable attached and the reciver is set to the right port
    Scholar:
  • 94 Answers
Please make sure that the connections are firm. Then check if the input mode is set to auto in. Also try to change the sound field on the receiver and try. If the issue perform reset by turning OFF the receiver and press n hold the MODE button along with the power button till S.F clear appears on the receiver and try. You can also try to disconnect and reconnect the power cord from wall outlet for 2 minutes and try.
Posted on Sep 26, 2009
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Sony bravia 285 and xbox surround sound.
a HDMI lead has sound and video cables
Jan 11, 2010 | Sony Electronics - Others
Sp.off
ON the str-de485 the sp.off lights up when the headphone jack is enabled, do you have the headphones inserted?
Feb 13, 2009 | Sony STR-DE485 Receiver
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
REQUIRING A PART NO LONGER AVAILABLE IN NZ
You need IC201 " 8-759-827-92 " IC M61511FP for your Sony STR-DE485 and this parts is available in Parts Store USA
Good luck.
Nov 04, 2008 | Sony STR-DE485 Receiver
Worked Fine and then my computer did not recive a wireless connection, and nao cant play my 360 :[
make sure the wireless part of the router is working fine by trying a computer to connect wirelessly to the router. if it connected fine then it is a matter of matching the wireless settings of the router and the xbox in order for them to synchronize properly.
Jul 02, 2008 | NetGear RangeMax WPN824 Router
Xbox 360 playing music
plug it into the xbox and select an option on it that is `normal` it is probably on intro.
May 22, 2008 | Samsung YP-K3 MP3 Player
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Nov 18, 2007 | Sony STR-DG510 Receiver
Sony STR DE485 (Audio Video Reciever)
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
May 05, 2007 | Sony STR-DE485 Receiver
Sony STR-DE485 Receiver Logo
224 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
