Question about Compaq Keyboard
Keyboard keys that have purple numbers are locked. Can't type.
The keyboard keys that have purple numbers are locked. I am unable to type letters on these keys, only the numbers. How do I unlock? I have a NEC Versa P8210 laptop. I have had to use my desktop computer to send this message? Thanks.
    President:
  • 547 Answers
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Posted on Sep 20, 2009
    Problem Solver:
  • 19 Answers
Hold th "Fn" key down and press F11 on your keyboard, the light should go off and you should be back to normal.
Posted on Dec 22, 2009
3 Suggested Answers
SOURCE: Aptonbook manual (laptop) and also keyboard layout
I don't know what all the symbols mean on my new laptop. How do I find out what they all mean?
Posted on Sep 16, 2008
Joed911
  • 4338 Answers
SOURCE: Compac laptop keyboard settings are wrong.
Hold the SHIFT & NUMLOCK keys on your laptop and it should fix the problem.
Or on some laptops: Hold Fn + Num Lock
Posted on Nov 30, 2010
Medion notebook typing normally. getting numbers instead of letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 05, 2012 | Medion md40298 Notebook
Numbers take precedence over letters on shared keys
On my keybard I have a FN function key and F13 locks it. It lights an indicator.
Carl
Jan 11, 2010 | Acer NSK8458AN Keyboard
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
Simply change my keyboard from typing numbers instead of letters..I.e. I'm trying to type yonkers and it gives me y6...I know it is a simple F6 or F2 function but I forget. Its been a while since I u
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Apr 26, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Unable to use keyboard
try to press caps lock and see if light goes on and off.
try to turn off the computer , check that the keyboard is connected to the purple port in your computer all the way, then turn on the computer.
Mar 24, 2009 | Computers & Internet
Keyboard
Click on start... and then on Run. Type access.cpl and then u will get accessibility options. Click on the Tab "Mouse". You will find a check box "Use mouse Key", uncheck it. It should work. Hope this helps you... :-)
Sep 04, 2008 | HP 386209-001 Keyboard
Compaq Keyboard Logo
559 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
