Question about Sony Handycam DCR-DVD105 DVD Camcorder
Screen Dim Records as if the lights are low
I have the 2006 model and just a little over a year of owning it the recordings slowly got dimmer and dimmer. The veiw screen is the same. I have checked all settings and it is as if I have the light realy low and records mostly in shadows.
  • luckysevn Dec 27, 2007
    Same problem! Color/light dims in and out, occassional "lines" across viewscreen, too... ???
Check the night shot plus button. put it off and try
Posted on Feb 02, 2008
My headlights only work on bright.No dims on both sides.All fuses good
GM switched from having the headlight switch provide power to the lights to having it provide the ground. There are relays for high and low beam circuits. I would start checking that relay for power and ground, then the dimmer switch.
Feb 15, 2015 | 2006 Chevrolet Trailblazer
I have a 2006 Ford Freestar SE minivan. When I try to set the dimmer switch to bright, the headlights turn off. They do however stay on as long as the dimmer switch is set to dim.
What you are referring to is the beam selector switch, i.e., low beam vs high beam. The headlight switch on the dash turns on the headlights set to low beam. Pulling the steering column lever toward you flashes the high beams; pushing the lever away from you turns on steady high beams. From your description, I believe you do not understand the function of the beam selector switch.
Mar 19, 2014 | 2006 to 2007 Ford Freestar Tire Pressure...
Citreon c4 model vtr year 2006. no main lights but i can get full beam
Try your dimmer switch, when they go bad we either have bright or dim.
Jan 28, 2014 | GMC K1500 Cars & Trucks
Passenger headlight dim /only on low beam
Depends on just how dim it is. If not too dim, I would first make sure the bulb is the same brand/model you have installed on the other side. It is very unlikely it's a problem with the dimmer switch, but may be a problem with the headlight relay or connector pins at the headlight.
Nov 02, 2017 | 1995 Chevrolet C1500
Why will my dim lights on my 2006 chevy trailblazer not work only the bright
Your low beam relay might be bad or the dimmer switch is faulty. A possible cut/corroded wire could also be to blame.
Jan 13, 2013 | 2006 Chevrolet Trailblazer
Low beams very dim and getting dimmer. Bulbs were replaced after low beams burned out a year ago. Local mechanic now wonders if there is a voltage problem. He says he had similar problem reported with...
a bulb burns out cos it got too hot.not because it got dim.....dim lights would be dim if the voltage was low but that would be unheard of by me.....(never come across that before).most common answer would be fitting cheap bulbs to start with...they dont last as long either....
Sep 10, 2010 | Subaru Outback Cars & Trucks
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
DVD records a black screen if tv is on standby.
You have tuned the dvd recorders channels? dont forget a recorder dvd/hd/vcr is actually a tv set without its own screen and to record from channels you need to have its on board channels tuned in... what you have been probably doing is using a function on many recorders that records direct tv... what this means is it records the feed back signal through the scart lead of what ever channel your tv is tuned to at the time that is why no tv on = no signal
Sep 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam DCR-DVD105 DVD Camcorder Logo
37 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
