Question about Troy ExtendNet PocketPro 100 (-2933A) Print Server
Need default password
I recently acquired a used Troy 2933A print server, which I have been able to reset, but need the default password to be able to login as admin.
Thanks
David
    Scholar:
  • 54 Answers
Username: admin
pword: extendnet
Posted on Dec 15, 2007
2 Suggested Answers
SOURCE: Default password
On some, password is access .
Posted on Feb 04, 2008
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Password????
Dear gbp7292, to access the admíns CP on this system yuou may try some of these "default" user and password combinations:
User System Password Manager
User Admin password 0000
User empty password 01234
If this still doesn't works, try doing a hard reset. To do this you will need to hold the reset button for 30+ seconds. After that, you'll have to reconfigure everithing.
Dec 06, 2010 | Linksys WPSM54G Print Server
What is the default password for D-Link DP-300U print server? Thank you
The D-Link DP-301U Print Server does *not* have a password by default. If you have come into the possession of one and it is password protected, then it is likely that the previous owner added a password.
In order to bypass it and reset the Print Server, while the device is powered on, you will have to hold down the RESET button on the back using a paper clip for 10 seconds.
[NOTE: If this helps, please leave feedback.]
Aug 11, 2010 | D-Link DP 301U (DP-301U) Print Server
I had forgot the printer server password. i had
Unfortunately, I don't know of a way to manually reset this without using the web-interface.
However, if it was somehow reset already, the default password for this unit is nothing. They do not use a password by default, so try it without one.
Ryan
Dec 02, 2009 | D-Link DP 301P (DP-301P) Print Server
Can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
Sep 05, 2009 | D-Link DP 300U (DP-300U) Print Server
A reset problem
Try using the PSAdmin software to do a factory reset (download it from the internet if you need to). If it demands a password try the following:
password: SYSXXXX (Where XXXX is the last four digits of the MAC address, which can seen on the underside of the server)
I learned about the password part from http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten, which has additional helpful details.
Jun 17, 2009 | D-Link DP 300U (DP-300U) Print Server
Password
By default the DP 301P+ does not come with a password. If there is one installed (and you don't know what it is), you can reset the device to factory defaults from the Tools menu in the web configuration utility. Be aware that you will lose all settings in the print server when you do this.
Cheers
Nick
Nov 17, 2008 | D-Link DP 301P (DP-301P) Print Server
Troy ExtendNet PocketPro 100 (-2933A) Print Server Logo
905 people viewed this question
Top Troy Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Troy Computer and Internet Expert? Answer questions, earn points and help others
