Question about Saeco Royal Professional Espresso Machine
Water is not hot enough for tea - Saeco Royal Professional Espresso Machine
    Sergeant:
  • Saeco Expert
  • 223 Answers
Go into your menu and make sure the temperatures of the small, medium and large cups are on maximum. If they are, then do what the Shaun said.
Saeco Parts and Service
www.cerinicoffee.com
Posted on Dec 14, 2007
    Problem Solver:
  • 4 Answers
Try using the cup heater to warm the cup before hand. Use a thermometer to measure the temp of the water coming out. If it doesn't reach 80 degrees, then the thermostat may need to be replaced.
How do you make a proper cup of English tea using a teapot?
There's more to making the tea than just shoving a few bags in a tea pot and adding hot water. Lovers of English tea believe that you need to warm the pot beforehand and let the tea brew before you start. Take a look at this article on the Yorkshire Tea website that gives a good run down of how to make tea.
http://www.yorkshiretea.co.uk/about-tea/yorkshire-tea-how-to-make-a-proper-brew.php
Feb 27, 2013 | Home
What kinds of dish warmers are there to keep food hot while on display
there are many kinds of dish warmers available to buy or hire:
most company's use tea light heaters or water heaters.
Tea light heaters work by having a number of tea lights under the food to keep it hot. there are also electric warmers available but they require a power source.
Jan 10, 2013 | Retail Supplies
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
How to make ice tea , in the iced tea maker
Recipe for Ice Tea
1. Take one teaspoon of Tea
2. Bring a small saucepan of water to a boil. Pour ½ cup water over the tea leaves. Brew for 3 - 5 minutes. Add honey, stirring well.
3. Add enough ice so tea reaches the 1-cup mark. Fill 2 tall glasses with ice. Add ½ cup tea and several lemon slices to each and stir.
Feb 20, 2011 | Mr. Coffee Iced Tea Maker TM1S
How do i make iced tea with my Keurig coffee maker?
In my experience it is not possible to make good tea with a coffee maker.
Tea needs to soak. 2 minutes for weak tea or if you like it like me 5 minutes for strong tea.
Coffee makers simply run hot water over the bean powder and don't soak it long enough.
L8ers
Sep 12, 2010 | Keurig Elite B40 Coffee Maker
How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Aug 15, 2009 | Bloomfield 8742 iced tea brewer, 3 gallon
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Water is not coming out hot enough for coffe or tea from my tefal quick cup
It won't be hot it's like tap water. Did you see the drain for the furnace?
Nov 25, 2008 | Heating & Cooling
Saeco Royal Professional Espresso Machine Logo
112 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
