Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Coils Continued To Freeze Up.....
Freezer coils have continued to freeze up after defrosting manually about every week for several weeks now. Frig is less than 5 years old.
I believe there is some type of defroster tube/element at the bottom of the coils. Could this have gone bad already?
Any specific help to this problem would be appreciated.
    Problem Solver:
  • 12 Answers
It could be the defrosting clock usually positioned at front bottom behind the removable grill or in the back. This clock times the running and defrosting time, so if stuck on run it will never go to defrost cycle and the ice piles up.It has a one way slotted fit. Use a wide flat screwdriver to slowly turn the dial until compressor stops, (defrost cycle) this will not only stop compressor, but also turn on that tube heather you where talking about to melt ice off evaporator. Then wait (up to 30 minutes) to see if starts up again(run cycle). If it does not, clock needs replacement. You can then turn clock again slowly to turn compressor back on so you can use fridge until repaired. You can do this off and on daily to manually defrost unit until repaired. If this is not your problem it could very well be the heather tube, but they rarely go out.
Best I can do without being there, hope it helps you.
Posted on Dec 14, 2007
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
My side by side coils freeze. I already changed out the mother board but within two weeks it freezes again. Any ideas?
You may have changed the wrong part.
The defrost heater and defrost thermostat are bad.
They are located inside the freezer coils behind the freezer panel.
Sep 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
ICe build-up on coils and frezer does not freeze after a few weeks from thawing.
Check the defrost timer which may be behind the kick-plate, inside the control panel or an Adaptive Defrost Control (motherboard) on the back.
Coils behind the freezer continue to "freeze up"
You have a problem in the defrost system There are three components: Defrost timer, defrost thermostst or terminator, and defrost heater. One of them has failed which is causing the evaporator to ice.
Apr 09, 2009 | Refrigerators
Freezer coils regularly freeze over
You have an automatic defrost problem. Here are the three components that can cause this defect in order of most common to least. #1 defrost timer or equivalent adaptive defrost control board, #2 defrost termination thermostat (should be replaced regardless since it has been frozen in ice several times) #3 defrost heating element(rarely fails but is possible). If you have a meter you can check the thermostat and element for continuity they should show an infinite reading if they are operational. the termination thermostat must be below 35 deg f to show a closed circuit.
Apr 02, 2009 | Refrigerators
Kenmoore side by side self defrost mode not operating correctly
when the coils ar emanually thawed does the water get removed by the drain ho;le or are you having to soak it all up with a shop vac? The drain may be frozen up and that would cause the water to stay in the freezer and product said that the coils foreese over after several minutes does tha fan come on and start moving the air over the coils? theres a sensor that should be bringing on the fan and that should keep the coils from freezing up. On thae back side of the panel is there styrofoam on it ? if there is stryofoam is part of it missing and the air flow now incorrect? Just a few more things to lok at. Thanks For using FixYa and don't forget to rate this solution please.
Dec 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by side works for a week, then freezer coils freeze up
defrost system problem tell me more,is the fan in the freezer working,can you find the defrost timer and put it in defrost?this way you can remove the freezer back panel and see if the defrost heater comes on,let me know what you find-mike
Oct 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Nov 15, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
