Question about Philips PET710 Portable DVD Player
No disc Hi, the problem is after I put a disc in, the screen says "loading" for a long time before "no disc" come out. Cant understand it and thanks for your help. :)
  • 128 Answers
Try cleaning it might help if not might just have to replace it
Posted on Sep 21, 2009
SOURCE:
Computer powers up, but nothing boots up firewire light goes out. solutions????
Try continually pressing the F8 key as it starts. You may be able to start it in 'safe mode'.
You haven't got a usb flash drive in one of the usb ports, have you? That can sometimes cause the problem you describe.
Any error messages apperaing on the screen? Don't forget the monitor cable ...
Aug 14, 2010 | E-Machines T6520 PC Desktop
Machine won't recoginze disc from program function
As I understand it, the Load button loads designs that you have prepared earlier and saved within the Designer 1, not disks made and saved in your Husqvarna software. These are the .DHV files (this might not be quite the correct file format name - can't remember!) you might see when you look at a disk in your software.
When in Program mode, you need to use the Menu button to go right back to the first D1 opening screen, then choose the Disk icon, navigate through all that to find your design, choose it and it appears on your Program screen. The second time you hit Menu from inside the program screen, you get taken directly to where you were the first time so it is quicker. But first time, it is a long slow process.
Jan 30, 2010 | Sewing Machines
Acer aspire not loading to windows
If you have recovery disc or back up disc put it in and restart the PC and start tapping the F12 key until at the Acer splash screen, you should get now see your boot order, now use your up and down cursor key to highlight the CD/DVD drive and then press enter, this will now start the recovery disc that you put in, just follow the on-screen instructions.
If you don't have a disc, restart the PC and at the Acer splash screen start tapping the ALT+F10 or just F10 and if you have a recovery partition on your hardrive then the recovery program will start up, just follow the on-screen instructions.
Thanks
Sep 09, 2009 | Acer Aspire T135 PC Desktop
Rear wheel setup vx 125 07
c34b1f2.jpg so is it ok and do u understand
Jun 13, 2009 | 2005 Gilera Runner VX 125
Hi, I have had the game thrillville off rails for ever and i have never used it because i dont know what do to. The box contains 3 dics and it says..disc 1..disc 2..and..disc 3. i have tried every disc and...
You need to install the game first. Install the discs in order starting with disc 1. Once you put it in the CD/DVD drive and close it, it should bring up the install screen. When it needs disc 2 and 3, it will prompt you to put them in. If disc 1 does not start installation, then you are most likely missing a disc that would be called "Install Disc". Hope this helps and if it doesn't, let me know.
Apr 10, 2009 | Logitech Dual Action for Pc (963292-0403:)...
My ps3 refuse sometime to load my ps3 discs.
I have the same problem, it's error 80010514.  An error occurred during start up operation.  That's what you would see on your screen if the disc would even get read.  Your ps3 is screwed.  Call 1-800-345-sony and talk to them.  They will tell you that you need to send it in and if your 1 year warranty is up you have to pay $150.  I'm waiting for them to send the coffin to send my ps3 back in
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
Hulk blu ray cant be played
is your hard drive almost full? Sometimes a full hard drive will not allow media files to be stored in order for playback.
Apr 07, 2017 | Sony Playstation 3 (PS3) Console
Hi, On my grundig vp6200, everytime I turn it on it has an error message that is not understandable to read. The only way I can overcome this problem is to click a box which then takes about a minute to...
Hi I recently had the same problem with my VP6200 and i opened it up back cover only 4 screws 2 at base & 1 each side 1 is behind small metal disc about 10mm diamater.
on opening it up i found the battery had expanded and was putting pressure on the hard disc.
i unplugged the battery connector only 1 way to refit.
and i made 3mm hole at top of battery foil to release pressure then i put pressure on foil to flatten again.
plugged in and presto it lives again.
I understand this problem has been around in pda's and laptops for some time now. Next i am looking for new battery. good luck. mikey
Nov 01, 2008 | Computers & Internet
No screen
Does the initial Toshiba screen come up before the Windows count down screen? This is the Toshiba, right?
Aug 23, 2008 | Toshiba Tecra M1 PC Laptops
Philips PET710 Portable DVD Player Logo
295 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
