Question about Mitsubishi WS-55511 55" Rear Projection Television
TV will not switch on, green light flashes for 30 seconds but it still does not come on.
We had the local power company cut the power for 2 hours. The TV was on when they cut the power but we have a surge protector on the power input. The green light flashes for about 30 seconds then goes out and when you press either the remote or the TV power on button it still does not come on. I have tried several times the reset button and still nothing. I have disconnected the control panel wiring and still the green light comes on but the remote will not switch the TV on. Anyone got some suggestions for this problem. I have not replaced the fuses (not sure where they are located to be honest) but I don't think this is the problem as there was a surge protector on the unit and all the other electronic items on the surge protector are fine. We have had a friends little girl round and she loves to touch the TV and the buttons so I thought maybe a button was stuck but disconnecting the 9 wires on the connector from the control panel that goes inside should have sorted this problem out. I love the TV but it is frustrating that it does not work. Please somebody help me!!!!!
    President:
  • 4,402 Answers
Know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Panasonic TH42PZ85B troubleshooting standby light flashing red and TV will not come on line?
Have exactly the same problem. Standby light flashing twice in 1 second then off for 5 seconds but will not switch on. This after switching off on the set following around 1 hour use.
Switched all power to set off for around 30-40 minutes
Jul 02, 2010 | Panasonic Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 14, 2009 | Directv RC23 Remote Control
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Jan 26, 2008 | Audio Players & Recorders
Mitsubishi WS-55511 55" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
