Western Digital My Book Home Edition 500 GB USB Hard Drive
Problem for Western Digital My Book Home Edition 500 GB USB Hard Drive
Dropped my WD my book too. now my computer won't recognize it.
By andreaebk on Sep 20, 2009
it still lights up. and when i try to safely remove hardware, the WD USB mass storage device shows up as an option. i just cannot seem to access the my book from the my computer folder as usual. is it broke? if so, how do i recover my files? oh no.
Best Solution
posted on Sep 20, 2009
Very Helpful)
Geekman
Rank: Guru  Computer Accessories  Expert
Rating: 85%, 1763 votes
The case maybe damage, so could the hard disk.
First try removing the hard drive connecting it to an USB hard drive adapter, if it works then you know the hard drive is OK and you only need to buy a new USB hard drive adapter case.
If the hard drive is faulty then you need to buy a new hard drive, but your data is gone because you cannot see the files on a faulty hard drive.
There are data recovery companies that can recover data from damages/faulty hard disk BUT it will cost you an arm and a leg for their services
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
bob_computer
Rank: Guru  Western Digital Computer Accessories  Expert
Rating: 87%, 1244 votes
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Was this helpful?
Yes
No
Popular Solutions for Western Digital My Book Home
Questions and Unsolved Problems for Western Digital My Book Home
Do you recommend Western Digital My Book Home Edition 500 GB USB Hard Drive?
Answer
Answer
My Book Home Edition won't turn off, won't be recognized by my Mac.
Answer
mybook home can not be seen by computer. Blue light never stays solid its just a rotating light.... (More)
Answer
i plug it in to the power source and my computer and it makes noises but the light doesn't flash and... (More)
Answer
input/output error and is making a clicking noise when starting up
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
