Question about HP PhotoSmart 7550 InkJet Printer
HP Photosmart 7550 printer
The black cartridge and tri color cartridge is saying that they have failed...I took them out and put back in several change in the message. The photo one is fine...goes in the same as the others. I have replaced the black and tri color TWICE now, so it is not the cartridges...HELP!!
  • 208 Answers
There are some print head cleaning modes you may want to try.
In your menus , look around for those and run the print head calibrations and cleaning procedures.
Also with the printer unplugged. Dampen an cloth with some rubbing alcohol and remove the print cartridges, lightly clean all the contacts with that damp cloth.
They may just have some ink on the contacts giving you a false failure message.
Hope this helps you out. They can be fickle.
Posted on Dec 14, 2007
My printer screen says
The ink is contained in a cartridge.
Note that "backup" printing mode mixes colours, to produce "black", because the "black" ink-cartridge has failed.
So, replace the BLACK ink-cartridge.
Jan 05, 2010 | HP Photosmart 8150 InkJet Printer
Green tinged photos on photo paper normal color output on plain
Assuming a 2 cartridge system, and you want B&W or sepia, pull the color cartridge and print away! Works for my HP DJ 5440.
Jun 30, 2009 | HP PhotoSmart 7550 InkJet Printer
Take out the cartridges and turn off the printer. Turn it back on, and THEN put the ink cartridges in. After that, try to print the calibration page.
If this does not work, clean your printer using the cleaning maintenance from your HP printer software
Jan 06, 2009 | HP PhotoSmart 7550 InkJet Printer
HP C6180 won't print in color using apple powerbook G4
go to advance properties and UNclick where it says BLACK CARTRIDGE ONLY , CLICK OK , and then try to print again , it should now come out in color.
Dec 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
May 14, 2008 | HP PhotoSmart 7550 InkJet Printer
Hp 7550 ink jet printer printing uneven
My first guess is that it is a cartridge issue, due to these printers having the print head as part of the cartridge, there is nothing else, it makes the whole cartridge the only printing item. Ensure the carts are not old (exp date) and that they are HP, With that all understood as I now see that you must due to owning it for 6 years, then you could try to clean the contacts on machine's "cartridge holder" and give that a clean too while your at it cause it may be the problem here (see below)
If a inkjet printer lasts 3 years you would be doing well, and you've had 6. Exceptional!
HP Photosmart printers may print images with white lines or single color streaks. This issue can be caused by ink that has dried in the ink nozzles or by debris that is blocking the ink nozzles. The ink cartridges and the and printer cradle should be cleaned. Clean the ink cartridges with the ink cartridge cleaning utility in the HP Printer Toolbox. Also, clean the ink cartridges and the print cradle manually.
Cleaning the ink cartridge cradle
  1. Assume an eye level position with the HP Photosmart printer.
  2. Locate the ink cartridge cradle.
  3. Using clean, moistened swabs, wipe the underside of each wall of the carriage where fibers may collect and come in contact with the paper. Repeat until no ink residue is seen on a clean swab.
  4. Reconnect power cord when finished cleaning.
Manually cleaning the ink cartridges
  1. Turn the printer on and lift the top cover.
  2. After the ink cartridges have moved to the center of the printer, unplug the power cord from the back of the printer.
  3. Remove the ink cartridges and place them wide side down on a piece of paper.
  4. Prepare a clean, foam-rubber swab or a lint-free cloth slightly dampened with water.
  5. Locate the copper-colored circuitry strip on the back of each cartridge.
  6. Clean the copper-colored strip with the dampened swab or cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate.
  7. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp foam-rubber swab or lint-free cloth. Use a dry foam-rubber swab or a lint-free cloth to remove moisture from the contacts.
Cleaning the ink cartridges with the HP Printer Toolbox
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab.
  7. Click Open the HP Photosmart Toolbox or Service this device.
  8. Click the Device Services tab. This tab does not display in Windows XP; proceed to the next step.
  9. Click Clean the Print Cartridges .
  10. Follow the onscreen prompts.
If you've got this far then I should tell you that these days, Printers aren't worth fixing, one just replaces them with new
Dec 17, 2007 | HP PhotoSmart 7550 InkJet Printer
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
248 people viewed this question
Ben Johnson
