ASUS P5VD2-MX SE Motherboard
Problem for ASUS P5VD2-MX SE Motherboard
I have 3 PCs
By Dharmasish on Sep 20, 2009
I have 3 PCs
-> 1st have 1 Ethernet port. (this PC have a laser printer, dual core processor, BSNL board band)
-> 2nd have 2 Ethernet port. (1 is Motherboard inbuilt & other is connected as NIC card in PCI port)(2nd PC have a HP photo color printer)
-> 3rd have 1 Ethernet port.
Q.. I want to share the Broad band, and the two printers. How ow can I connect these 3 PCs in one network
Best Solution
posted on Sep 20, 2009
Very Helpful)
juyruyrfiujh
Rank: Wiz
Rating: 81%, 690 votes
http://www.geekgirls.com/windowsxp_home_network.htm
or
http://windowshelp.microsoft.com/Windows/en-US/help/76174f4a-7522-425a-9424-324dd299265e1033.mspx
or
http://video.google.com/videoplay?docid=-4885804885278005452#
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" help " - Dharmasish
Solution #2
Not Rated)
Geekman
Rank: Guru  ASUS Expert
Rating: 85%, 1840 votes
You need to get a DSL or cable modem router or it maybe a separate router and a cable or DSL modem. Get an Intermet Service Provider and their recommended modem router combination also select a plan that suits your requirements (ie costs, broadband speed, and download limit). This modem router needs to be configured in accordance with the IPS settings.
If the modem router does not have at least 3 network RJ45 Ethernet ports then you will need a hub that has 6 or more ports.
The computers are then connected to the modem router with LAN cables. If there is not enough ports on the modem router then connect the computers to the hub and then connect a LAN cable from the hub to the Ethernet port on the modem router.
All the computers need to be in the same Workgroup, and the IP address have to be configured to obtain an IP address automatically and Obtain DNS server address automatically.
If you need to print from any computer, the printers need to be shared.
If you need to copy or move files between computers then the hard disks and or folders need to be configured for sharing.
If you need further information, please contact me.
Was this helpful?
Yes
No
Popular Solutions for ASUS P5VD2-MX SE Motherboard
Questions and Unsolved Problems for ASUS P5VD2-MX SE Motherboard
Do you recommend ASUS P5VD2-MX SE Motherboard?
Answer
Answer
hp tablet motherboard
Answer
Dear sirs I had a hardware defect that can be defined as a component severely damaged by little fire... (More)
Answer
Report abuse posted by lanang22game on Mar 29, 2009 No Sound in Vista Ultimate Mobo P5VD2-MX SE... (More)
Answer
merhaba anakartim hdd usb gibi goruyor. bunu nasil cozerim
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , NY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
