Question about Zebra 105Se Thermal Printer
I have a problem with me zebra 105 se, the problem is the ribbons is tense and then the ribbon is broken
Problem with ribbon tense
  • mark186 Jun 26, 2008
    Ribbon take up spindle winds so tight after 50-100 labels can not get J hook off. I have replaced take up spindle, oiled the felt washers on supply ran the printhead tension all the way out but nothing has worked.
  • Anthony Schenck
    Anthony Schenck May 11, 2010
    Will need a little more information. Are you wanting to change the tension ?
  • 38 Answers
Your supply spindle is "too tight".
Procure a "Washer Felt w/lube kit" (Zebra part number 01688-140) and rework the supply spindle. Use only the supplied silicone oil to service the felt washers.
Adjust the tension on the spindle in accordance with the service manual procedure.
Posted on Jul 17, 2008
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
Error condition ribon out for zebre 105 sl
This may be due to the fact that your ribbon is too translucid, back quality transfer films.
To overcome this you must use a bit of scotch and a piece of film and stick it on the ribbon sensor.
Else try a callibate to see if the error is not solved
Sep 19, 2011 | Zebra 105SL Thermal Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Hello, We have a printer card Zebra p120i
either your ribbon sensor is not working or somehow you skipped it when you threaded the new ribbon.
Nov 26, 2017 | Zebra P120i Thermal Card Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
I have Broken ribbon message on the LCD display. I just changed the ribbon and the clean cartridge. Hellp
It could be that the printhead is damaged or the ribbon sensor needs repair. Call Zebra troubleshooting for help. If it is under warranty you can send the printer back to zebra for repair. Takes about 3-5 days. All the info is on their website. good luck.
Jun 16, 2009 | Zebra Eltron P330i Card Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
436 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
