Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I need help with my machine Singer Futura CE250
I don't know why it sews like this. When it first starts sewing the first stitches are too loose. I can see the little loops when it goes over it to embroider on top of it covers the stitches up like it's supposed to but since the stitches were too loose they come out through the sides.
And on the bottom the bobbin thread is too tight because it's just pulling the top thread. It also pulls too much thread and it'll bunch up on the bottom. I tried tightening and loosening the little screw on the bobbin but it's not working. I don't know if it's too tight or too loose!
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 51 Answers
SOURCE: Hi, I'm trying to embroider
The plastic drop-in bobbin case, is the worst I have ever seen. The thread will get jammed in it or it hops while the machine is sewing. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
Posted on Sep 06, 2009
SOURCE: Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
Posted on Dec 26, 2009
  • 255 Answers
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
I have a Singer Futura CE250, I am having trouble pulling the bobbin thread up
Be sure you are using a brand new needle. If that doesn't help, the machine is probably out of time. Search for sewing machine timing or take it for service.
Mar 08, 2017 | Singer Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Bobbin case on singer ce250 thread gets hung up and pulls bobbin case out of place
is the needle inserted correctly--flat side goes to the back of the machine
the possiblities are
worn or broken gear
machine could be out of time
needs to be serviced
Feb 27, 2012 | Singer CE-200 Quantum Futura Computerized...
I am having the same problem as angelmdb.. I have a new computerized futura and am trying to just straight stitch with it.. it starts off fine for about 8 stitches then beeps and stops.. i wait it will do...
Go to singerco.com and under customer support, look at frequently asked questions, they have alot info there. If, that doesn't work for you, call customer service at 1-800-4singer and they can advise you
Sep 20, 2010 | Singer CE-200 Quantum Futura Computerized...
Wrong stitch
The tention on your machine is too loose. wcbotha@yahoo.com
May 12, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE250 Futura problems with timing and bird nesting
Needle could be loose or bended or use another size. Put the needle all the way out and the insert a new one inside making sure is the right way in (flat part hasto be looking oposite of you).
another thing is that the Tension could be too tight.
Last, Rethread the machine with another thread to make sure is good.
Hope it helps
Feb 17, 2010 | Singer CE-200 Quantum Futura Computerized...
New machine
Most probably the sewing machine driver is not installed properly. You can launch troubleshooting utility and send its repot to Singer to find out why it happens.
Feb 13, 2010 | Singer CE-200 Quantum Futura Computerized...
Copy of Software
I have the autopunch software. I may help you. (futura ce250)
Apr 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
225 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
