Question about Fedders AEQ07FBG Air Conditioner
AC wont shut off
LG unit, only a couple months old. Rather not deal with warranty repair. Unit is set to 75 in cool mode. Unit never stops running though. A seperate thermostat confirms room goes down to 55 degrees.
I have moved what I believe to be the thermostat sensor on the intake. I moved it to the middle of the intake so it would get lots of air, and same thing. Room has plenty of circulation so there should not be any hot spots.
  • 126 Answers
While unit is running tap control to see if it shuts off or turn therm. up to 80 if still runs replace control (warranty)
Posted on Dec 14, 2007
My 18,000 BTU LG window AC: The compressor wont shut off.
replace the thermostat
of course it will not stop if the air in the room is not controlled ( doors open , window open, room to big fore the ac unit or if the temp control is set too low ( 25 c is optimum setting)
Aug 10, 2016 | LG Heating & Cooling
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
FEDDER'S PORTABLE UNIT SAYS STOP. WONT RUN
Disconnect power to the unit and reconnect. If "stop" is still on the display you will probably need a qualified technician to trouble shoot. The best mode is the snowflake (cooling). The rain drop is dehumidification which can cause condesation on unit.
Aug 30, 2009 | Fedders A&B Chassis A1A07W2B Air...
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Air conditioner
1.check thermostate switch
Aug 29, 2007 | Mitsubishi MSH09TW Air Conditioner
AC WILL NOT SHUT OFF
SOUNDS LIKE THE T-STAT TEMPERATURE SENSING BULB IS OUT OF "AIR-FLOW" (SOME CAN COME LOOSE FROM THEIR MOUNTING CLIPS) OR IT IS BAD ALL TOGETHER ... MOST MANUFACTURERS HAVE A ONE-YEAR WARRANTY ON SMALL PARTS AND 5 YEARS ON THE COMPRESSOR .., HOPE IT HELPED.
Mar 27, 2007 | LG LWHD1800R Wall/Window Air Conditioner
Fedders AEQ07FBG Air Conditioner Logo
93 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
