Question about Eclipse CD8445 CD/MP3/WMA Receiver
I need help
I put a new batt in my car and now i cant turn the stereo on i need a code cd8445 sirius radio
help me please
I need a securiity code 4 my panasonic in dash
Posted on Apr 22, 2008
    Problem Solver:
  • 8 Answers
Contact on your car dEALER....and ask for you pass code or stereo code....:)
Posted on Dec 14, 2007
I just bought a new radio for my jeep and it says it is SiriusXM ready. Does this mean all I have to do is get a plan?
No this means you can control Sirius radio with your car stereo, but you still require A sirius external device. In other words your looking for simply a Sirius add-on Kit for your stereo, If the kit comes with controller, which most do, then the fact your new car stereo is Sirius Ready, makes the Sirius controller obsolete. I hope this helps.
Carlos Q
Apr 05, 2015 | Jeep Car Audio & Video
Engine noise through sirius
First check fo good ground on lighter socket sometimes manufacture's use whats called a floating ground which is one wire connecting every socket for a ground . This creates what is called a ground loop and can create noise. Instead of rewiring try an inline noise filter. check with your local car audio store. Hope this helps. If not write back.
May 06, 2010 | Sirius Satellite Radio sp-tk2 Satellite...
Need codes for stereo in order to turn on radio
Some Honda radios will give you their serial number by turning key to on position then push 1 and 6 button at the same time then turn on radio. It should display the radio serial number. You will need to give that number to a Honda dealer service advisor to search for the radio code. Or let the dealer do it for you. Sometimes people will put the number in the glove box door or operators manual because everytime Batt. power is lost or disconnected,you have to enter the code to get the radio and nav to work.
Oct 16, 2009 | 1996 Honda Accord
Radio code 2000 S70 VOLVO
it does have a back up battery on your radio but to make sure of it just get the code.
Apr 15, 2009 | 2000 Volvo S70
2001 stereo code.
The stereo's ESN Feature has activated. High-end Eclipse stereo's have a feature to prevent theft where if the battery is disconnected from the stereo, it must be "unlocked" with a "key" CD, that comes with the CD player but can later be changed to a personal CD of the owner. You would need to either call Eclipse and see if they can de-activate it (you'll need to ship it to them, if they even do it, because it is a security feature after all.) Or you need to talk to the last owner of the vehicle and have them unlock it.
Jul 26, 2008 | Eclipse CD8445 CD/MP3/WMA Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Sirius shots down after a sec...
make sure your device is fully charged, then attempt to turn on again. you may need to use the restore tool available thru the sirius website or mysirius studio.
Mar 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Stuck on 255??WTF
you need to call sirius and activate the new unit the id number is on the bottom sir-alp1 unit or the box it came in
Jan 28, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Unlocking radio
I have this problem almost everytime I have to do it.  It's such a rare occasion.  If I remember correctly, just press and hold the key that moves you to the next number... the >>| key, I believe.  After a couple seconds it'll beep & open up (provided you have the correct code).
Oct 23, 2007 | Kenwood Sirius KDC-MP425 CD Player
Eclipse CD8445 CD/MP3/WMA Receiver Logo
166 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
