Question about Sony Ericsson Walkman W810i Cellular Phone
Not even able to turn on my phone.. etc
I can't turn my phone on, even after charging it for 3 hours. There is red flashing underneath the right most button... Also, I hooked it up to my computer, but of course that doesn't do a thing considering it is off.
  • 1,944 Answers
Try taking out the battery overnight and remove memory card. Then on the following day replace the battery (don't put the memory card in) and try turning it on. If this doesn't help then the phone needs to be flashed (SEUS/wotanserver/mobile operator). Good luck!
Posted on Dec 14, 2007
My JBl Synchros E50BT Bluetooth headphones wont charge or turn on.
sadly the battery has possibly died and will never charge .
Oct 19, 2016 | Cell Phones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
How to turn on
To turn on the phone. First ensure the phone is properly charged, for about 2 hours. Then you press and hold the end call button or the red button that is on the right hand side for about 8 seconds, it will turn on, it might even turn on before the 8 seconds is complete.
The moment you see the phone light come on, release the red button.
Thank you for using fixya.
Sep 13, 2011 | Motorola Mobility MOTORIZR Z3 Cellular...
Phone doesent turn on flashing red light when you push the power button. please help.
Try this , it helped me. 1. plugin the charger (or data cable) for about 15 minutes and keep the red light blinking. 2. while the charger (or cable) is hooked to the phone, remove the battery and memory card for 10 to 12 seconds. 3. keep the memory card out and put the battery back in and whalah, it startes up. (really hope this helps)
Nov 14, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Flashing red light
I had the same problem, blinking for no apparent reason. I shut off phone, removed battery, put battery back in, turned on. No more red light. Not sure if the charging routine gets stuck in some loop or what, where it doesn't realize it isn't charging anymore? I think it's supposed to blink while charging isn't it? Sure would be helpful if the manual said SOMETHING about it.
Aug 06, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cant get it to turn on or charge
Flashing red light 3 times and won't boot. I recently recalibrated the battery and again the 3 flashing red lights. Seem to be draining the battery fast. It's also a new battery...which work for about 2 weeks before the 3 flashing red lights first started. Now 2 batteries later. It won't boot.
Apr 26, 2009 | Gateway MT6840 Notebook
Sony ericsson w580i
the EROM file on your phone is corrupted that is why it just flashes red and not boot-up, you need to have the EROM reflash for the phone to work again.
Jun 18, 2008 | Sony Ericsson W850i Cellular Phone
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Sony Ericsson Walkman W810i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
