Question about Harman Kardon AVR 630 Receiver
Se830 receiver I have se830 receiver which was working properly until today, there is no picture no sound it's all blue on tv
0 characters
1 Points
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
My TV brings up message "No Hard Disk Found" and doesn't show pictures
sounds like the hard drive went in the Digital TV box, call your local tv cable company for a replacement.
May 08, 2015 | Audio & Video Receivers
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio & Video Receivers
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Harman Kardon AVR 630 Receiver Logo
451 people viewed this question
Top Harman Kardon Audio & Video Receivers Experts
Electro Med Services...
Are you a Harman Kardon Audio and Video Receiver Expert? Answer questions, earn points and help others
