Systemax Venture PC Desktop Logo
Posted on Dec 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pc dont start
I have this problem my pc systemax venture pc dont start up , i hear the fan and the red indicate light put on like a second and dont start
  • elo27 Dec 14, 2007
    how i now if the PS function well??
Anonymous
Level 3:
Genius:
  • Master 1,226 Answers
  • Posted on Dec 14, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1226
Questions
Helped
622398
Points
3211
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
I need to remove the fan from mother board. Are there instructions on line or a diagram explaining how to remove it.
http://reviews.ebay.com/Do-It-Yourself-Computer-Fan-Replacement_W0QQugidZ10000000000104252
Try these instructions... All fans are roughly the same procedure.
1helpful
Need new internal fan.
Well meaure it in mm or in inchs, then convert it to mm. Then buy the fan off of newegg.com just make sure you get a two ball bearing fan because they last allot longer.
CAN'T FIND ETHERNET CONTROLLER DRIVER FOR MY SYSTEMAX VENTURE SERIAL #106722446. DOWNLOADS FROM SUPPORTFORYOURPC.COM DIDN'T HAVE THE DRIVER.
You can always use a program like driver genius or Boot from a Knoppix cd and run ls pci from the command window. If the card is not integrated in the motherboard pop it out and get the numbers off the card itself.
Worst case scenario is put a 10 dollar pci ethernet card in it :)
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
2helpful
Montior turns off when hooked up to tower.
Remove the video card and try to put it back in. Make sure that it is fully seated. If that doesnt work, then try replace your video card
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Top Systemax Computers & Internet Experts
Ngoro
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
