Question about HP LaserJet 1220 Printer
Firmware for HP Laserjet 1220
I recently bought a new PC Formatter board from HP for my Laserjet 1220. Unfortunately it is shipped with an out of date firmware version and needs upgrading. The firmware is not available to download from the HP website, and HP support is not willing to supply it. Do you know of place where it can be donwloaded foc?
  • Anonymous Dec 04, 2008
    no firmware abalable on internet plz anybody help
Nope. It is not available from the HP Authorized Serice Providers site and the manual has no mention of how to obtain the latest firmware.
Sorry
Posted on Dec 14, 2007
Try searching limewire or kazza you may get lucky with somebody shareing a download you need
How do I eliminate Error 81.0185 EI01?
normally can be the network card. upgrade the jetdirect firmware and the printer firmware if you can, otherwise you need a new formatter board. before buy a new formatter you can try to bake its chip, warming it until 280°C for 20-30 seconds (but cover plastic parts around). sorry for my english
Mar 04, 2015 | HP LaserJet P3005dn Printer
53.11.03 error dimm 2 bank
try to reload the firmware or new firmware by going to the hp.com website and downloading the firmware utility tool. if it does not work the formatter board needs to be replaced.
Nov 10, 2013 | HP Color LaserJet 5500 Printer
HP Laserjet 4345mfp after memory count finishes control panel goes blank(display is working but all black) nothing else happens. I've already replaced formatter, dc controller and engine power supply,...
I'd be willing to bet that when you changed out the formatter, you used the silver square looking flash dimm from the old board and put it on the new board, If you replace the flash dimm I think your problem will indeed go away... 8mb Flash Dimm
Sep 12, 2011 | HP LaserJet 4345mfp All-In-One Printer
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
Keeps dispalying mem test faliure 1/6 replace dim 0?
Somewhat common failure code on the P3005 machines. Unfortunately this means that your formatter board has failed. Your machine MAY be repaired under warranty depending on it's warranty date with HP. Just contact HP and give them your printer model and serial number and have them check the warranty status. Trust me in what I am telling you, HP has had a large number of P3005 formatter board failures. If you want more info just do a google search on "HP P3005 formatter" or "HP P3005 dimm 0" and you will see this is a problem.
Good Luck and Thank You using Fixya.
WheatlandServices
Nov 26, 2010 | HP LaserJet P3005n Printer
My hp laserjet 3005n keeps going to sleep and won't wake up to print.
Hello, In this situation you really have 2 -3 choices. The first being just to live with it, power cycle the printer when required. The other choices are to make sure the printers software of Firmware is up to date. The last choice would be to replace the formatter board. The firmware file is easily uploaded to the printer, the file can be downloaded from the following location http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=ca&prodNameId=1846102&prodTypeId=18972&prodSeriesId=1846088&swLang=8&taskId=135&swEnvOID=54
Download the file and unzip to a known location on your compter, be sure to read the "README" file as it contains the instruction to upgrade the firmware. If after upgrading the firmware and the problem remains, you could purchase a new formatter from www.partsnow.com or any Hewlett Packard parts distributor. I wish you luck and I hope this has been benificial to you!!!
Aug 24, 2010 | HP LaserJet P3005n Printer
My HP M2727nf scanner pulls more than one page through at a time causing paper jams and interrupting the scan function. How do I diagnose the cause?
Hi this is a typical symptom of the firmware being out of date. Go to the hp website and download the latest firmware upgrade utility. If the firmware is updated and the problem continues it could be a problem with either the dc controller of the formatter board.
Al
May 07, 2010 | HP M2727NF Laserjet Printer
49.4c02 service error in hp laserjet 2300n
HP 2300 ERROR 49.XX
• A critical firmware error has occurred on the printer
• Turn printer off then on
• Disconnect the parallel cable or the network cable
• If message still there when the network cable is disconnected
upgrade firmware in jet direct card and the formatter board
• Bad network cable
• Replace firmware DIMM
• Replace the jet direct card
• Replace formatter board
• Replace engine board
95% of the time it is a PDF that has a font that is not recognized by the printer! If the error is not there when you follow the above, you may have to clear out the print queue.
Apr 23, 2010 | HP LaserJet 2300 Printer
I now have 2 HP LJ P3005n printers within the past 3 days that have stopped working. 1st error code on printer #1 is = 49.4C22 and 49.4C02 and the 2nd printer is now displaying error code = 49.4C02. What...
The codes indicate firmware errors (possibly a failure of the formatter board, but more likely firmware). Up-to-date firmware is available for download at www.hp.com/support/LJP3005. Read the installation instructions for the firmware update. If you have ANY doubt AT ALL about your ability to successfully update the firmware, pay a shop to do it for you. A failed firmware update may not be recoverable, and the formatter board is rather costly.
Oct 20, 2009 | HP LaserJet P3005n Printer
Was trying to send a fax - now it says Error 70 turn off and back on - have done this 5 times.
It can be a defective fax module or formatter, but most likely, it is a software issue.
Make sure you have the latest firmware.
When/if firmware is the latest version and problem persists, go to Menu -> Service -> Restore Defaults.
If problem persists, it might be a good idea to try a different land line, if you have one available, before purchasing new hardware.
Please note you need a different board depending on which region of the world you live in. I'm assuming North America here.
The fax module for the 2840, is about $27.31.
Part information:
Q3977-60011 - PC Board (Interface) : Line interface unit (LIU) PC board - Telephone interface board for the printer.
If the problem is in the formatter (main board), the price goes up to $405.65. Please not, that the LIU (fax module) is included in this.
Part information:
Q3948-69006 - Formatter / LIU assembly (for North America) - Includes the formatter PC board, the line interface unit (LIU) PC board, and the metal card cage.
Jul 15, 2009 | HP LaserJet 2840 Printer
HP LaserJet 1220 Printer Logo
250 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
